RC8 rebuild
im going to rebuild all the diffs and shocks...
does any1 have any good tips about what weight diff and shock oil to use? |
i like 555 575 777 stock setup is 573
I run 555 in my diffs, never tried anything else so I can't speak on any other setups. As for the shocks if you're running Big Bores 6x1.4 pistons and 30 or 35wt in front and 6x1.2 or 10x1.1 pistons and 25wt in the rear should be a good starting point.
i have to agree 555 works best for me to
so run 555 on all the diffs?
yap front 5,000 center 5,000 rear 5,000 ae diff fluid
5k in all the diffs works best for me too.
Do you have the big bores or original shocks? With the regular shocks I prefered 35wt front and rear with the 1.5x2 pistons. I think they come built with 1.6x2 and 45wt oil from the factory. |
Originally Posted by PTP Racing
(Post 5810072)
