Old 05-12-2009, 07:35 PM   #1
Default serious question
please don't laugh. But can you put a piston in backwards????
dreaux is offline   Reply With Quote
Old 05-12-2009, 07:35 PM   #2
yes
-TKO Competition Development-Sidewinder Fuel-
Alan D. is offline   Reply With Quote
Old 05-12-2009, 07:36 PM   #3
ok. so will it ruin it??? if it was???
Old 05-12-2009, 07:37 PM   #4
jrwoodchuck's Avatar
but if you put it in backwards from backwards, it would then be correct.
Doug
TLR 22/M-11
“Looks like I picked the wrong week to quit sniffing glue.”
jrwoodchuck is offline   Reply With Quote
Old 05-12-2009, 07:40 PM   #5
Originally Posted by jrwoodchuck View Post
but if you put it in backwards from backwards, it then would be correct.
i see what your saying. Ha Ha. What would the symptoms be if it was backwards. My engine is getting worse and worse. Now it won't evern idle. I took it apart last week. Have not run it much. Have i destroyed my engine if it was backwards??? My engine has seemed to GAIN compression. Now that aint right.
Old 05-12-2009, 07:40 PM   #6
No. It just won't run right. Put the longer part of the piston toward the exhaust port and make sure IT IS NOT AT BDC and place your backplate on.
Old 05-12-2009, 07:43 PM   #7
would this explain why it stalls alot at mid to high speeds and imposible to tune??? also it seems virtually impossible to put it on at bdc.
i feel like a jackass. I am pretty sure it is backwards
Old 05-12-2009, 07:46 PM   #8
If you thinks its backwards open it up and check it. It should be easy to put it at bottom dead center.
Old 05-12-2009, 07:46 PM   #9
is this why i have been getting a enourmous amout of fuel leaking between my manifold and engine???? Lots of blubbery rich build up of fuel??? My car has also been backfiring???? have you ever heard of a car that detonated in the muffler or outside of it???? Man i have created one helluva piece of work.
Old 05-12-2009, 07:46 PM   #10
No it shouldn't run if it is in backwards. At least on my motors. One side of the piston is usually longer than the other and fits into a slot on the backplate. Cant remember if the slot is for the short side or the long side though.
fazznick is offline   Reply With Quote
Old 05-12-2009, 07:48 PM   #11
i am confused. First you say don't put it at bdc. the you say to put it at bottom dead center. are you saying that put it on at tdc then before i close the backplate put it at bdc and mark the flywheel or something?
Old 05-12-2009, 07:50 PM   #12
Check your gaskets make sure they're not torn. The longer portion of the piston is meant to cover the exhaust port on the compression stroke so it is possible that if it is backwards then the fuel that is in the crank case is coming out the pipe. If it pools around you manifold and block you probably have a torn gasket.
Old 05-12-2009, 07:51 PM   #13
When assembling your motor make sure it is not at BDC. Once assembled it should be easy to place the piston at BDC.
Old 05-12-2009, 07:52 PM   #14
Mine ran
Not good though
Old 05-12-2009, 07:53 PM   #15
yes i have been shreding gaskets. i am on my third pair in a week. My piston is in backwards. Fuck.
how bad have i ruined my engine???
Kyosho VoneR Thread neons Nitro On-Road 12206 06-29-2012 03:19 PM
Another begginer/returning question mark in wi Electric Off-Road 21 08-12-2009 07:51 PM
Awesome Mugen MTX4 For Sale Ed Delgado R/C Items: For Sale/Trade 22 08-13-2008 09:47 PM
OS .12TR (11A) engine problem stonely0 Nitro On-Road 18 08-25-2006 01:47 AM
Aarcmcc Rules TrustMe Australian Racing 43 10-10-2005 01:15 AM
Serious gas engine question. pro engine tuners look here Ron Nitro On-Road 28 11-13-2001 03:27 PM
