Old 05-10-2009, 05:24 PM   #1
Default question about racing
one question. If you are bliping around the track and when you get to the straight away and you and you build up for wot if it bogs down is it still to rich??? If i make a couple high speed passes (back and forth on the straight) there is no bogging down but when i run the whole track just bliping the triger when i turn for the straight it has a hard time reaching top speed. does this mean i am my engine is too rich and getting loaded with fuel??? Still not going over 220 230. I need more zip in the straight away.
dreaux is offline   Reply With Quote
Old 05-10-2009, 05:37 PM   #2
is anybody out there?
Old 05-10-2009, 05:45 PM   #3
Sounds like it is rich, slowly lean it until this pretty much disappears.
LRP Z.28R - 3
Spur Gear - 0
howtowakeakar is offline   Reply With Quote
Old 05-10-2009, 05:59 PM   #4
revo61's Avatar
Trader Rating: 18 (95%+)
Lean the low end a little, try 1/8th of a turn at a time.
JQ The Car Black Edition/Reds R7E/Reds 2113 pipe
Airtronics MT44/Savox servos
Sidewinder Team Strike V2 30%
USA.JQRACING.COM / WWW.NEMORACINGUSA.COM
revo61 is offline   Reply With Quote
Old 05-10-2009, 06:14 PM   #5
cluffy1's Avatar
Default glow plug
this can also be caused by the clow plug. change to glow plug and see if it makes a difference before you start messing around with the tune.
cluffy1 is offline   Reply With Quote
Old 05-10-2009, 06:17 PM   #6
thanx for that advice. Last i checked the plug was still good. But it is the original plug that came with the engine. I probably should check it again.
Old 05-10-2009, 06:28 PM   #7
Definitely switch it out.
I will switch mine out now every 1/2 gallon or so.
Had my original in for 1 1/3 gallons, made a big difference when I put a new one in.
LRP Z.28R - 3
Spur Gear - 0
Old 05-10-2009, 06:36 PM   #8
imaxx21's Avatar
Send a message via AIM to imaxx21
try changing out the panty hose on your air filter...
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 05-10-2009, 07:21 PM   #9
lol!!! you were there?? Which one are you??? I think the stockings are a pretty good idea. I have extra filters and a new mugen neck on the way. But to be honest i like the one from xray better. Mugen redesigned that in thier upgrade kit which i did not get.
I know i am a terrible driver huh??? but i am getting better. When i get good enough i will race. I would also like a new servo for my throtle.
Old 05-10-2009, 07:30 PM   #10
Ace DS1313, good for everything, and only $75.
Or you could always get a new high-voltage JR servo, OVERKILL X 10.
LRP Z.28R - 3
Spur Gear - 0
Old 05-10-2009, 07:46 PM   #11
dreaux, i have some OFNA LX engine parts if you need some. you will have to come pick them up though because i don't use the postal service because they will steal/lose your packages!!!
Traxxas super speed is my weapon
Ryan Roma is offline   Reply With Quote
Fastlane Raceway kansasracer Kansas/Missouri Racing 17300 08-18-2017 04:41 AM
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 05:09 AM
1/12 Pan Brushless Lipo Rubber Tire Class? reenmachine Electric On-Road 53 05-18-2012 06:05 PM
A few questions... Agent Nitro On-Road 22 02-11-2006 09:29 AM
What scares you most about racing? onebeatuptc3 Electric On-Road 81 12-11-2004 04:57 PM
TB-01 question? Whacky Electric On-Road 9 08-16-2004 07:11 PM
