Old 05-09-2009, 05:36 AM   #1
Default question about top dead center
My engine has good compression with the plug in. But if i take it out and rotate the flywheel to tdc its like the piston almost stays there and the flywheel has play in it like it will move back and forth about a eigth of a inch while it seems the piston is not moving at all. Almost like its clicking back and forth at that point without any compresion. But i can feel just a tad bit before that point. This is with the plug out. Is this normal? sorry for all the questions.
dreaux is offline   Reply With Quote
Old 05-09-2009, 06:46 AM   #2
bumpity
Old 05-09-2009, 06:50 AM   #3
I think that a small amount of play is normal, seeing as I just removed the glowplugs and moved the flywheel at TDC on 2 different motors.
LRP Z.28R - 3
Spur Gear - 0
howtowakeakar is offline   Reply With Quote
Old 05-09-2009, 07:13 AM   #4
How old is this engine?
LosiMadMan is offline   Reply With Quote
Old 05-09-2009, 08:02 AM   #5
Davidka's Avatar
Trader Rating: 75 (100%+)
A tiny bit of play is unavoidable, if it's excessive then the rod bushings are worn. A usual running symptom of this is an engine that otherwise runs well but idles inconsistently and goes through glow plugs quickly. If you think the play is more than a tiny bit, replace the rod.
Old 05-09-2009, 08:48 AM   #6
rc-mike's Avatar
I don't think it is very old but look at his other threads and you will understand.
rc-mike is offline   Reply With Quote
Old 05-09-2009, 09:40 AM   #7
Little play is normal & is refered to as piston dwell time time in real car motors basicly relation of piston moving in a verticle plane & big end of rod moving in a mostly horizontal plane. When you build a hotrod motor most people look for longer dwell time for a torque application by using a piston with the wrist pin hole higher than stock so they can use a longer rod & increase piston dwell,so what I'm saying is its not always a bad thing. This is the motor you just had uh problems with correct? You can pull the back plate off & do the same test & look at where the rod & crank pin meet.If you can see the crank move inside the rod much you got problems & by move much I mean if you can see the rod gush oil out between the space between the 2 then suck it back in when you turn the other way thats the beginning of the end.V-spec crank pins have proven to be uhh less than hard enough there.The good news is once that starts you'll know within a few fuel bottles(500cc bottles)by exactly what Davidka described & soon wont be able to keep it tuned,only with my personal v-spec a new rod did not help much as the bronze bushing in the rod seems to be harder than the steel crank in a v-spec.
Be creative with the search function & you'll come up with more symptoms of this problem & see what the people did to fix it like tune was off or crank was replaced or they just freaked them selve out & motor was fine.You can ebay cranks between $35-60 fairly often if you need to,just make sure you need to before you do cuz like I said some movement is normal & I wouldnt have even said anything if I hadnt read some of your other posts.
butch man is offline   Reply With Quote
Old 05-09-2009, 08:38 PM   #8
chunk t's Avatar
Originally Posted by butch man View Post
Little play is normal & is refered to as piston dwell time time in real car motors basicly relation of piston moving in a verticle plane & big end of rod moving in a mostly horizontal plane...
Nice butch man
I do all of my "degree wheel" timing via a spread sheet & measurements of the various engine components. On a spread sheet it's easier "see" the dwell time and track the piston's acceleration and deceleration as the crank goes through its rotation.
chuck "chunk" thomas
1:10, 2-wd Stadium Trucks
B-Mod Tunnels
If ignorance is bliss... I must be in heaven!
chunk t is offline   Reply With Quote
Old 05-09-2009, 09:36 PM   #9
conecting rod and crankshaft are fine. After all i put my engine through it is normal after all. I can stop being paranoid now
Old 05-09-2009, 10:29 PM   #10
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
It's an OS, they don't hold metal pinch at TDC like others do. The lack of pinch just means your engine is fully broken in. What you really want to check for is compression with the plug IN. That is the only thing that matters.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
SAVAGE - SS, .25, .21 Official Thread! Horatio Monster Trucks 11167 05-15-2017 08:40 PM
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 05:09 AM
To shim or not to shim that is the question nitrohead5300 Onroad Nitro Engine Zone 19 03-25-2013 07:45 PM
STS engines sparksy Onroad Nitro Engine Zone 2774 02-03-2013 06:05 AM
Academy's new 1/10 scale buggy SBV2 PRO rcforum Electric Off-Road 2964 12-10-2011 11:16 AM
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 01:47 PM
Any Tips for Jammin Mike.CL Electric Off-Road 13 03-15-2007 05:44 AM
