Old 05-08-2009, 07:39 AM   #1
Questions?? help!!! rc8 loose in rear
ANYONE HAVE ANY HELPFUL INFO HOW TO GET THE REAR OF THE RC8 TO BE NOT SO LOOSE,AS IN SQUIRLY.I HAVE TRIED 555 AND 573 IN THE DIFFS THANKS TODD
bigdaddy963 is offline   Reply With Quote
Old 05-08-2009, 07:46 AM   #2
cary's Avatar
Trader Rating: 67 (100%+)
this may help silver or black sway bar ,rear hub uper hole
silver rear springs 555 diffs may trie fiber clutch shoes like
1 fiber 2 alum
Xray XB8 14,AE RC8T3,XB9 13,Kyosho wheeler,Losi SCTE 2.0,+ More
> The Animal,Frank L. Jr. <
~~~~RedRock Hobbies~~~~
cary is offline   Reply With Quote
Old 05-08-2009, 08:47 AM   #3
Maybe try softening up the rear shocks a little use softer clutch shoes and lighter springs, I'm gonna get drunk now.
Joey Platinum is offline   Reply With Quote
Old 05-08-2009, 09:03 AM   #4
Flying Monkey's Avatar
Trader Rating: 54 (100%+)
mine was too and i added a little more toe out on front and fixed it right up. only went 1 more degree
MONKEY BUSINESS RACING
Flinging poo at a track near you! Winning hearts and minds everywhere!
www.graphicmonkeydesigns.com
Brooksphotodesign.net
Flying Monkey is offline   Reply With Quote
Old 05-08-2009, 12:16 PM   #5
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
I'm not personally familiar with the setup options on the RC8... IF this set of adjustments is an option, you might try this:
1) make the rear camber links as long as possible- in other words, if there are options to go inside or outside holes on the rear uprights/hubs, put them outside... and on the inside holes on the shock tower.
2) If you can change the roll center (by moving the inner end up the rear camber link up or down where it mounts to the shock tower) raise it.
3) If there are adjustments for position of the rear arms (further forward or further back) put them forward to put more weight on the rear wheels.
4) Increase the toe-in in the rear.
Don't do those things all at once, try one at a time... otherwise you may make the rear TOO planted, which makes the car tend to push. It is all about a balanced approach.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 05-08-2009, 12:23 PM   #6
mfrosty's Avatar
Trader Rating: 14 (89%+)
+1 and all those adjustments are available
~TQ Racing~O.S. Engines~AKA~Answer R/C~
http://www.youtube.com/user/frostyone1977
mfrosty is offline   Reply With Quote
Old 05-08-2009, 10:35 PM   #7
Thanks guys I will try some of these things and see if it helps
Old 05-08-2009, 10:46 PM   #8
porkchop's Avatar
Send a message via AIM to porkchop Send a message via Yahoo to porkchop
charles garten
serpent / novarossi / Desoto Racing / Absolute Hobbyz / ko propo / first turn racing usa / KustomRcGraphics / O'donnell racing fuel / Houstons Engine Service / sweep racing tires
porkchop is offline   Reply With Quote
Old 05-11-2009, 08:58 PM   #9
thanks for the helpful info. I found part of the problem this weekend.I found most of my assend looseness was when I was off the power in the curves or on the power in the ripple bumps,so I believe a lot of the problem is to stiff rear springs
Old 05-11-2009, 09:59 PM   #10
bmxRRT's Avatar
I'm using the RC8T rear carbon shock tower in my RC8FT, helps a LOT.
O'Donnell Z01-B(E) Team
Mamba Monster 2200kv
Futaba BLS 451
Airtronics M11x
bmxRRT is offline   Reply With Quote
