Old 05-07-2009, 02:40 PM   #1
JFAB's Avatar
Trader Rating: 15 (94%+)
Default need Go engine help!
Just bought a used go 3 port R and pulled it out and cant turn in over by hand the pinch at the top is tight but can get it around but at the bottom it just stop like in the pic on both sides.
Is somthing worng or is it tight? It seems like the rod is rumbing aginst the case and thats what is stoping it.
Team Driver For: Hotbodies, Reds Racing USA
JFAB is offline   Reply With Quote
Old 05-07-2009, 02:49 PM   #2
jpz_67's Avatar
Trader Rating: 56 (100%+)
Its hard to tell but it looks like there are some pieces of aluminum or gouges on the bottom crankcase just below the rod!
Agama A215, Futaba, Nitro Pro Fuel, Proline tires, Triton Engines, Savox.
jpz_67 is offline   Reply With Quote
Old 05-07-2009, 02:58 PM   #3
HaulinBass's Avatar
improper bearing installation
HaulinBass is offline   Reply With Quote
Old 05-07-2009, 03:01 PM   #4
JFAB's Avatar
The guy said he rebuilt it the bearings have 1 and 3/4 gallon and the conroad piston and sleave have 3/4 a gallon on it.
What should I do from here?
Old 05-07-2009, 03:13 PM   #5
HaulinBass's Avatar
pull the piston sleev rod and crank and heat up the engine, when its hot stick the crank in and use a mooden dowel inside the crank bore to push the rear bearing in so its seated properly.
Also check the piston and sleeve for scoring or gouges around the ports.
Also If you buying an engine used and the seller says there is anything less than two to three gallons on it or its not brand new, chances are they are lieing. No one sells engines that quick unless there is something wrong with them, unless they are new.
Old 05-07-2009, 03:17 PM   #6
will g's Avatar
Trader Rating: 132 (100%+)
Send a message via MSN to will g
its the con rod its in backwards the line im seeing goes to the inside of the engine not the back
Will Garza
TLR 22SCT Tekin RS Pro-Fantom 9.5/TLR 5ive-T
will g is offline   Reply With Quote
Old 05-07-2009, 03:20 PM   #7
rearviewmirror's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rearviewmirror Send a message via Yahoo to rearviewmirror
You should have bought my 5-port!!!!!!!!
ARCTIC DOG RACING (Nitro free since 2009)
"Straights are for fast cars, curves are for fast drivers...."
8ight-E / 8ight-TE / T4 / Slash
rearviewmirror is offline   Reply With Quote
Old 05-07-2009, 03:22 PM   #8
Not true. I have a Go 5-port for sale that I put 3/4 of a gallon through. It was broke in by Pro Twister Mods and runs perfectly. I am just done with nitro. Not everyone selling nitro engines is evil!
Old 05-07-2009, 03:39 PM   #9
HaulinBass's Avatar
Not everyone but a good percentage of people, either that or every engine has a gallon to a gallon and a half of fuel lol.
Old 05-07-2009, 04:07 PM   #10
JFAB's Avatar
YOUR THE MAN! Thanks pulled it spun the piston 180 and BAM works great. Don't know if the guy went through it and put it in backwards or what but the con rod piston and don't have any bad chips grooves or scratches.
Old 05-07-2009, 04:10 PM   #11
will g's Avatar
glad i can help that motor is tons of fun in buggy thnx will g
Will Garza
Old 05-07-2009, 04:14 PM   #12
Yeah, exactly.
Did the person sell it to you with the conrod backwards?
Team HRC Raceway - http://www.hrcraceway.ca/
Semple is offline   Reply With Quote
Old 05-07-2009, 04:28 PM   #13
JFAB's Avatar
Yeah that's how it came
Originally Posted by Semple View Post
Yeah, exactly.
Team Orion CRF Wasp Rev X-Dyno results Nano Onroad Nitro Engine Zone 1531 11-07-2010 01:43 AM
CEN Matrix TR t4usee Nitro Off-Road 1798 03-29-2010 09:57 AM
vspec or ninja??? dreaux Nitro Off-Road 32 07-04-2009 07:17 AM
Which one of these 2 r/c's should i get? Zeeshan Rookie Zone 36 03-17-2009 09:08 PM
Need HELP with V-Spec Mo-Bo0st Nitro Off-Road 9 07-12-2008 08:47 AM
Help with a AXE mamba .21 grivero Nitro Off-Road 17 05-11-2008 02:50 AM
