No 2wd nitro CORR
Ok I love the 2wd CORR trucks but I am a nitro guy. Anybody had any luck or even tried to make one out of a GT2? I have searched nobody makes one.
i guess u could use the bumpers off the sc10 and the suspension arms off of it but im not sure if the suspension blocks are the same as the gt2 cause it is based off a t4 inless it uses the same parts
Corr trucks are defined by their scale-like wheels and tires. You wouldn't be able to get any power down on those tires with nitro. So far the only nitro corr truck that appears to run well is the AE SC8, I've seen a Traxxas Slayer run, it wasn't so good.
by all means try it but I don't know if you can get much power down...but try it though it would def be cool 2 see
Originally Posted by Davidka
(Post 5782871)
(Post 5782871)
there is no demand for 2wd, because people can't drive 2wd.
1/8 buggy is so big because it is easy to drive. all the 1/8 heros come to our track in the winter time and 1 out of 10 can drive a 2wd buggy or truck. look at 1/10 gas truck, there isn't even a roar class for them any more. if you can wheel a 2wd gas truck, you can drive anything. |
well 2wd not really that hard to drive to me espially gas truck u baseilly just let off the throttle before u get in the turn then tap the brake. but i can let off and getting stright but i would let off and before i turn hit the brake and a guy thats real good with them told me not to do that and let off let it roll then tap the brake to go into the turn . but i know people say that if u can drive a 2wd u can drive anything but i drove a 1/8 buggy totally diffrent then driving a 2wd and jumping wise too.but man 1/8 are so much easier to jump with
Originally Posted by jnslprd
(Post 5783499)
yea well i think gas truck are that touchy espially with rotary carbs and with the smoothie pipes out now its not bad at all. now electeic 2wd truck thats at diffrent story they are touchy i really dont care for them .
