Old 05-07-2009, 08:31 AM   #1
rcgeezer's Avatar
Default Pipe Cleaning
What's the best way to clean both the outside AND inside of a fairly dirty tuned pipe? Mine has some mileage on it, and I've been neglecting it lately. Time to get it back in tip-top shape! Thanks for your suggestions!
**Team Terribles Northern CA Regional Rep.**
Cold Fusion R/C Products Team Driver
Answer-RC USA / Team Sweep Racing USA
Team RcRenew...visit us at rcrenew.com!
Triton RC Alpha Plus Engines
rcgeezer is offline   Reply With Quote
Old 05-07-2009, 08:35 AM   #2
S.O.S. PAD WORKS GREAT ON THE OUTSIDE
jmpn02 is offline   Reply With Quote
Old 05-07-2009, 09:16 AM   #3
if it is not anodized you can use oven cleaner then polish with semi-chrome.
drrm123 is offline   Reply With Quote
Old 05-07-2009, 09:29 AM   #4
Send a message via AIM to Deznuts05
anti-freeze or wd40 in a crock pot and let it sit for a few hours (8-12hrs)
a sonic jewelery cleaner with wd40 is the hot ticket however finding one large enough to hold a pipe is the issue.
Rudy Diaz
"Power is nothing without control" Ryuken
Deznuts05 is offline   Reply With Quote
Old 05-07-2009, 09:34 AM   #5
RBMike's Avatar
Easy-off oven cleaner on a peice of cardboard in the driveway. Spray it allover inside & out. Let it sit for 15 minutes. Hose it off. Wear rubber gloves.
-EMBX6,T8 1400, RX8, 5S Lipo ,Elite-RC, RCM tray
-EMBX6,T8 1350, RX8, 5S Lipo ,Elite-RC, RCM tray
-B44 (Novak)
-ROAR 4 cell rule Blows
RBMike is offline   Reply With Quote
Old 05-07-2009, 09:48 AM   #6
Trader Rating: 26 (100%+)
Rudy Diaz
+1 The easiest way, have not used WD40. Use straight Antifreeze, no 50/50 mix, it'll clean and loosen inside and out. Depending on how built up it is internally will depend on how long you need to let it cook off. You can get a cheap crockpot at Walmart large enough for 2 for around $15.00
REDLINE RC RACEWAY
ldp787 is offline   Reply With Quote
Old 05-07-2009, 09:55 AM   #7
well story goes I was wd40'n some bearings then some plastic parts and I thought hey... why not try dump'n my header inside and see what will happen...
well to my suprise I pulled the header out and it was back to the polished ali look on the inside, rather than that gray oily look from running rich and gathering deposits.
But yes 110% anti-freeze will work like no joke. Go straight up and let it simmer for a few. When you're done you could probably use some metal polish but more than likely your first few tanks the outer shine will be gone.
The only advantage of cleaning pipes and headers would be to clear out the internals for a free flowing exhaust. The metal shine is over rated and last only about one day if that.
Rudy Diaz
Old 05-07-2009, 01:51 PM   #8
Someone I know has a sonic cleaner for car parts.
2 minutes and all the carbon is taken off of a boat motor cylinder.
LRP Z.28R - 3
Spur Gear - 0
howtowakeakar is offline   Reply With Quote
Old 05-07-2009, 02:38 PM   #9
rcgeezer's Avatar
Sonic would be nice but I can't imagine it would be very cost-effective for pipe cleaning.
Old 05-07-2009, 04:54 PM   #10
houston's Avatar
Trader Rating: 91 (100%+)
anti freeze is the best for inside and out
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 05-07-2009, 06:12 PM   #11
8&stuff's Avatar
Trader Rating: 55 (100%+)
keep a crock pot full of GREEN 100% antifreeze in the corner of the basement(with lid on&pot inside box) at all times. just dont forget that your pipes are cooking(will be hard to forget with the odor lol). every couple weeks i throw a couple pipes in to keep them tidy...
Mark Buecker
8&stuff is offline   Reply With Quote
Go-Tech Engines Thread MassiveMods Offroad Nitro Engine Forum 15106 06-26-2017 04:07 AM
Pipe cleaning brc358 Nitro On-Road 61 09-05-2010 09:10 PM
Pipe and Header Cleaning BigC2007 Nitro On-Road 12 03-19-2009 08:17 AM
Cleaning your car Dredd Nitro On-Road 21 03-24-2007 12:34 AM
