Old 05-05-2009, 05:14 PM   #16
easyryder's Avatar
wd40
XRAY XB9. Rubber tires with foam inside and super glue to keep them on. Cheap, but fast radio, high dollar servos, savox, mostly.
Cheap .21 engine. Modern starter box, finally!
easyryder is offline   Reply With Quote
Old 05-05-2009, 07:24 PM   #17
Didn't get a chance to clean it today because of Cinco de Mayo. Alcohol day.
If I have work tomorrow I won't be able to do it tomorrow either, but I'm hoping work doesn't call me to come in tomorrow so I can clean my stuff.
eighty2 is offline   Reply With Quote
Old 05-05-2009, 07:26 PM   #18
Originally Posted by yoshgixxer View Post
what kind of car is it?
Losi XXXNT.
Old 05-06-2009, 01:44 PM   #19
Not to sound like a broken record, but pull radio tray and engine, simple green and a scrub brush. Lightly WD40 and wipe off excess. Also, I use a siphon sprayer with denatured alcohol to spray off my engine and radio tray. It won't hurt your electronics.
Miniracer23 is offline   Reply With Quote
Old 05-06-2009, 02:30 PM   #20
offr0aden's Avatar
Everyone has there own way, you to will have one to. It comes with time
I carry a couple old paint brushes, one 2 inch stiff, and one 2 inch semi soft. Between rounds, I knock off the heavy stuff, then blow and brush off the small stuff. Also, carry a scrubbing brush for the tires. It makes for a quicker and cleaner, clean up once home.
Like others, I remove my electronics, engine / pipe. connect the pressure line to the fuel tank outlet. Then simple green and wash. Then reassemble.
When, between races, like our series races. I'll soak her down and wash, then take the diff's out / clean all the gears, bearings, check linkages. Replace anything for the next race.
The small parts and parts when cleaning in the sink or from the hose, I'll use a hair dryer on heat, to blow off and dry the parts. It makes for less time drying and I don't have to spray WD-40 on everything, just the parts I'm working with.
Good luck .. and stick with it... you'll be a pro in no time
offr0aden is offline   Reply With Quote
Old 05-06-2009, 05:28 PM   #21
freestylinmotox's Avatar
I personally use a wrag thats heavy duty, Nitro Clean, air compressor, and brushes of all sorts!!
Always worked for me!! I only spray wd40 into bearings and driveshafts. wd40 is a lubricant, Not a cleaner. Thats when Nitro Clean, air compressors, etc. come into play.
when in doubt, throttle out! braaap!
freestylinmotox is offline   Reply With Quote
Old 05-07-2009, 07:27 AM   #22
I did what everyone pretty much told me to do and she looks so much better. The only problem is my throttle and brake linkage needs to me adjusted now. I screwed it all up. Lol. I start her up and she is already turning her wheels at 20+. Lol.
Old 05-07-2009, 08:00 AM   #23
take the arm off and center the servos first then put the arm back on where it was in the beginning.
Making a comeback !!
roadracer43 is offline   Reply With Quote
Old 05-07-2009, 09:54 AM   #24
I did that, and it still wants to go nuts. I start it and it wants to just go. Won't idle. I dunno what to do. Blah. This is a frustrating hobby. Lol.
Old 05-07-2009, 10:01 AM   #25
smracer31's Avatar
Send a message via AIM to smracer31
Turn on your controller and let the servo center itself, then put on your throttle linkage making sure that the carburetor is fully closed.
smracer31 is offline   Reply With Quote
Old 05-07-2009, 10:09 AM   #26
Send a message via AIM to Deznuts05
Indeed however that's part of the fun. Try these:
http://www.amainhobbies.com/product_...oducts_id/7029
Those will make sure your carb is closed all the way up to the IDLE Screw.
Next, turn on your radio and center the tirm. then turn on your RX; followed by attaching your servo horn and then the throttle linkage.
Question, prior to cleaning was the truck able to idel before? Just currious because you make have to reset the needles, which is really easy.
Rudy Diaz
"Power is nothing without control" Ryuken
Deznuts05 is offline   Reply With Quote
Old 05-07-2009, 10:14 AM   #27
Rudy Diaz
It did it but it wasn't as bad. Before the wheels spun to the point where when I put the wheels on the ground the car would barely move. Now if I dropped them, the car would take off at about 15 MPH. The carb isn't completely closed right now. Does it need to be completely closed to idle?
Old 05-07-2009, 10:23 AM   #28
Regional Moderator
marccaracer's Avatar
Yes, it rests against the idle screw with just a tiny opening.
Jeff Mann
marccaracer is offline   Reply With Quote
Old 05-07-2009, 10:44 AM   #29
Well few things you'll want to look at.
1. Check idle gap on the carb. Check the motor manual as it will prescribe the appropriate setting. If you don't just post up the Make and model, I'm sure someone will know straight off the bat the proper setting.
2. You said it would spin the wheels on the starter box, that's the sign of the clutch engaging.
2.1 Check the following, Clutch shoes, Springs, Bearings and Clearance.
2.2 Since you're doing some spring cleaning it wouldn't hurt to either replace the wear items (shoes and springs) and refinish the clutch bell.
Post up if you still have Q's.
Rudy Diaz
Old 05-08-2009, 06:48 AM   #30
I still dunno what the deal is. The throttle is pretty much all the way closed, and it still wants to take off. I dunno what to do.
It is a Losi XXXNT with the stock engine and tranny. The only non-stock things are the a-arms, chassis, and the Traxxas EZ Start.
Tekin RX8 1/8 Scale Brushless ESC Thread sharkman Electric Off-Road 18828 08-07-2017 10:08 AM
PICS OF YOUR RC NITRO OFF-ROAD CARS busta774 Nitro Off-Road 391 07-02-2010 04:01 PM
o.s. tz help needed tony montana Onroad Nitro Engine Zone 12 04-15-2007 08:24 PM
Car internals dirty, need to clean hermanpu Nitro On-Road 7 04-26-2005 11:23 AM
