Old 05-05-2009, 08:00 AM   #1
Default Spur Gear Slip
I put larger tires on my XXXNT so I could drive in the grass, then she stopped moving. The tires still spin when I hold them off the ground, but when I put them on the ground, the spur gear slips. What causes this, and what do I need to do to fix it?
eighty2 is offline   Reply With Quote
Old 05-05-2009, 08:06 AM   #2
Chill_Will's Avatar
Trader Rating: 32 (100%+)
Easy check list first:
Make sure the slipper is tight
Make sure the wheels are on correct. If you don't get the pin in the wheel slot the axle will spin inside the wheel.
Check your diff. If it's too loose it will slip under a load.
A-Train racing (Woooooo Wooooo!!)
Chill_Will is offline   Reply With Quote
Old 05-05-2009, 09:02 AM   #3
I could be my wheels. I'll check when I get off work and see. I'll post back then. Thanks for your help Will.
BMI's DB12R Mr. Shookie Electric On-Road 8730 02-11-2017 11:12 AM
TC3 Forum Lowrider Electric On-Road 12162 12-30-2016 04:19 PM
kyosho electric offroad b-man777 Electric Off-Road 9014 12-22-2012 07:36 AM
diff and slipper adjustment questions builthatch Electric Off-Road 23 01-01-2010 05:47 PM
1/10th EP TC Knowledge Base rmdhawaii Electric On-Road 10 08-01-2007 11:45 AM
2and fly wheel now has to be replaced classic xl Monster Trucks 13 06-25-2005 07:31 PM
