Old 05-04-2009, 08:07 PM   #1
Default best way to get dirt out of engine.
just curious.
dreaux is offline   Reply With Quote
Old 05-04-2009, 08:08 PM   #2
pyromania's Avatar
Trader Rating: 18 (100%+)
what did you do this time?
Jesse Carrillo
Team Driver For:
TLR | Horizon Hobby | Nitrotane | Spektrum | HandleITHobbies | 818 Designs
pyromania is offline   Reply With Quote
Old 05-04-2009, 08:10 PM   #3
I would say the best way is to flush it out, take everything out of the case, flush the case and hit it with a compressor for a fair bit of time. Then replace everything except the case, carb, button and cooling head.
That would be the "best" way?
Team HRC Raceway - http://www.hrcraceway.ca/
Semple is offline   Reply With Quote
Old 05-04-2009, 08:11 PM   #4
Take it apart & soak/flush in a tub of fuel then blast with brake cleaner.But if you know dirt has gotten in you know it has gotten to your bearings & rod bushing already.
butch man is offline   Reply With Quote
Old 05-04-2009, 08:19 PM   #5
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Are you serious with this? What did you do to that poor v-spec now? Best way is to not get dirt into it to begin with.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 05-04-2009, 08:41 PM   #6
Tech Legend
Wild Cherry's Avatar
Take motor apart
Rinse every part clean with motor spray
Use the crank to spin and flush grit away from main bearings
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 05-04-2009, 08:44 PM   #7
cary's Avatar
Trader Rating: 67 (100%+)
all this and it still runs the poor thing dam it will be lucky
to see a gallon of fuel i hope for you it does
you got to brun um to learn um
Xray XB8 14,AE RC8T3,XB9 13,Kyosho wheeler,Losi SCTE 2.0,+ More
> The Animal,Frank L. Jr. <
~~~~RedRock Hobbies~~~~
cary is offline   Reply With Quote
Old 05-04-2009, 09:06 PM   #8
kaya's Avatar
how can one guy have so many things happen lets see
water not 1 time but 2 times dirt dead rx battery
engine gos wfo striped screws cluch bell rings
put the pipe down and step back and think
kaya is offline   Reply With Quote
Old 05-04-2009, 09:11 PM   #9
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
RC10-B6d | RC10-B64d
SmacTrac
#WeAreAE #ReedyPower #AE4Life
Trevor Williams is offline   Reply With Quote
Old 05-04-2009, 09:35 PM   #10
Integra's Avatar
Originally Posted by Trevor Williams View Post
X2.
Old 05-04-2009, 10:21 PM   #11
yoshgixxer's Avatar
Trader Rating: 73 (99%+)
i would recomend just taking the filter assembly off and running it in the sand...That V-spec must be bullet proof and made of kryptonite...
Hell you probably could just fire it up and hold it wide open the submerge it in the bath tub (i call it auto clean) ....through in some bubble soap for some extra flare!!
JK!!
yoshgixxer is offline   Reply With Quote
Old 05-05-2009, 12:40 AM   #12
MrUnlimited's Avatar
Originally Posted by dreaux View Post
just curious.
Remove the engine from the car. For the outside I use a brush and then I remove the glowplug and spray (upside down) WD40 though the carb. Then I put it for 10 minutes or so upside on the bench to make sure all the WD40 is gone. Then I mount the plug back and the engine in the car..
U5 Formulaboat 1/8 hydroplane - MHZ138 AQUAMANIA - Axial Exo Terra - Tamiya Avante - LC Racing EMB1 - Atomic AMZ 4WD Touring car
MrUnlimited is offline   Reply With Quote
Old 05-05-2009, 06:40 AM   #13
cary's Avatar
makes one think that you mite have a point
Old 05-05-2009, 07:27 AM   #14
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
+1... just curious...
Let me guess... you didn't ziptie the filter tube around the carb neck, and it came off?
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 05-05-2009, 07:31 AM   #15
DOMIT's Avatar
p.s. are you anywhere near Bossier? If so, come to the big race there NEXT weekend (not this coming weekend) and I will see if I can help you. Just find me... I look like my pic. My truck is hard to miss too... (RC truck that is) it is the only bright freakin' yellow 56 Ford body on a truggy.
Tamiya TRF 801X 1/8 Buggy! bola Nitro Off-Road 2517 02-13-2017 09:11 PM
New to 1/8 On road. UPSguy Nitro On-Road 87 05-01-2008 08:28 PM
DuraTraxx vs. Super Brain Charger battlecat Rookie Zone 16 08-08-2007 09:32 PM
off road electric getting some what interestin b-man777 Electric Off-Road 54 09-21-2006 06:10 PM
quality nitro fuels? Rockram Rookie Zone 8 03-15-2005 09:30 AM
Please help.The good and the bad of current cars. speed2004 Nitro On-Road 55 07-11-2004 11:22 PM
