Old 05-04-2009, 06:58 PM   #16
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
Originally Posted by yoshgixxer View Post
thats what were doing here..it would be cheaper to make a speed converted to a mugen top end then converting a JX to a o.s .speed botom end..that crank and bearing is expensive!
hey EZ have you taken your mugen sleeve out of the case since you have ran it?? You know how the case will leave "marks" on the sleeve? do the spliters in the case for the intake ports inter fear with the longer intake ports of the mugen sleeve??
AFAIK, the internal case port slots are identical between the Speed and JX case when I last checked. The Speed sleeve and JX sleeve ports are shaped about the same. The VSpec sleeve has a difference on the side ports and exhaust ports though.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 05-04-2009, 09:20 PM   #17
22Racer's Avatar
Trader Rating: 67 (100%+)
i take it you pinch sleeves?? im not negative to doing that but i am nervous about the "method" some people do it...i wanna be certain the sleeve maintains 100% roundness...also that it is not overly pinched..i think if i were to get one pinched i would only want a "mild" pinch unelss other wise recomended...i cant see the need to have it super tight!
what method do you use and what is the price?
I am a machinist and the method I will keep it rounder than any method out there. I do not overpinch like some I've heard do. 2 tanks an hour or two richer is all thats needed for break in. I charge $15.00 to pinch a sleeve shipping included back (Us only) $35.00 for the whole motor cleaned, inspected, pinched and rod installed if you send it with. I also stock Tko bearings if needed.
I am not an Os fan but the speed and the Ninja are good motors, only downfall is they tend to lose there pinch faster than some (especially if ran too hot)other brands but do tend to run well with less pinch than other brands.
I am not sure why but my friend says if he got his speed over 250 deg. he lost pinch, after pinching the motor a couple times it has gotten warmer than that but didn't lose it's pinch like before.
Rex
Rw modding and engine repair http://www.rw-mods.com
Sleeve resizing $15.00/ motor rebuild $30.00
Argus engine distributor/Avid bearings/ Alpha engines/
Fx Royal engines/ Maxy Engines
e-mail rwmods@yahoo.com Rex Welch
22Racer is offline   Reply With Quote
Old 05-04-2009, 10:48 PM   #18
yoshgixxer's Avatar
Trader Rating: 73 (99%+)
im going to get the mugen pis/slv for the hell of it,its only 115 bucks...
i noticed this too..they loose there "metal" pinch pretty quick..but maintain decent compression for a long time...7 to 10 gals...is not very uncommon..but with the plug out you can spin it over effortlessly....kinda worries me too but if it runs it runs..ill usually replace the sleeve when it starts having a unstable idle...
for $15 bucks ill send out a piston and sleeve to you and have it done as long as it stays round and has the correct taper im down! Sounds like you know what your doing...should i clean up the piston and sleeve before i mail it to you???Also please pm me mailing adress/payment instructions...
just took a few times to beat it into submission
yoshgixxer is offline   Reply With Quote
Old 05-05-2009, 08:50 AM   #19
reggie l.'s Avatar
a freind of mine thinks he may get out of the hobby and he has about a quart on this motor hasnt even been tuned yet...with tko ceramics and its moddified..if i get it i wil just take my speed crank out of my vspec and put it in there..it will be a screamer
_ClockWork-Racing_
http://www.clockworkracingengines.com/
~8t 2.0
~MUGGIFIED Lst-xxl
reggie l. is offline   Reply With Quote
Old 05-05-2009, 09:23 AM   #20
yoshgixxer's Avatar
were do you race reggie? i used to live in pikesville! right near randalstown...
Im up in york know and mostly race at nuclear,Xtreme and hobby town for out door..
if your pulling the crank out do you want to sell the piston sleeve and rod?? what model engine is it??
Old 05-06-2009, 08:18 AM   #21
reggie l.'s Avatar
i race all over xtreme,nrc(im in the point series), awsome in va, blue dimond..every where thats in a 3hour drive range...
but pikesville man thats right down the road
if your tlking about wat im pulling my speed crank out of(i want to keep the speed crank btw), its an vspec modded by tnt with tko ceramics in it..no scraches on it a screamer (is that wat you mean?)
_ClockWork-Racing_
~8t 2.0
~MUGGIFIED Lst-xxl
Old 05-07-2009, 08:48 AM   #22
reggie l.'s Avatar
pro mod spped is supposed to be the very 1st speed the 1 with the most power
http://www3.towerhobbies.com/cgi-bin...1p?&I=OSMG2067
_ClockWork-Racing_
~8t 2.0
~MUGGIFIED Lst-xxl
Old 05-07-2009, 10:41 AM   #23
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Actually the Pro Mod is a pretty new engine. Both the speed and speed AL were out before it was.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 05-07-2009, 01:56 PM   #24
yoshgixxer's Avatar
what the hell is that!!! i never even herd of it..but it looks bad ass!! looks the same as a speed but $100 cheaper....i wonder what the sleeve looks like??
what cars do you race reggie?? ill be at xtreme weather pending if it rains ill go to nuclear on sunday..
if you want to sell the piston/sleeve set out of the V-spec let me know
Old 05-07-2009, 02:17 PM   #25
It is a standard v-spec sleeve!
-Koby Kubrin-
Old 05-07-2009, 05:13 PM   #26
reggie l.'s Avatar
nooo man im saying its supposed to be the old mag head 1 that they stoped making... and now put the vspec head on it with all the 1 speed mods and internals etc
_ClockWork-Racing_
~8t 2.0
~MUGGIFIED Lst-xxl
Old 05-07-2009, 05:15 PM   #27
reggie l.'s Avatar
its the same internals as the mag head speed..
monster truck and truggy...sold my mugen 5bx5t cause ima losi man so i got a 8t 2.0 pending on a sale...we will see in the next day or 2
and naa id rather just sell the whole motor
_ClockWork-Racing_
~8t 2.0
~MUGGIFIED Lst-xxl
Old 05-07-2009, 05:16 PM   #28
See my above post. The pro mod uses the normal v-spec sleeve!
-Koby Kubrin-
Old 05-07-2009, 05:41 PM   #29
yoshgixxer's Avatar
how much for the old motor?? what crank will it come with a stock V-spec?
That prospec V-spec probably still runs good though..i see it comes with the easyer to use carb...the difference between the speed sleeve and the Stock V-spec sleeve isnt that much anyways..the biggest difference is the wider exhaust port...that i noticed
Old 05-07-2009, 05:50 PM   #30
reggie l.'s Avatar
if i get my ninja ill sell it to you for $100 moded vspec crank and ceramic bearings and moded sleeve
_ClockWork-Racing_
~8t 2.0
~MUGGIFIED Lst-xxl
