Old 05-06-2009, 12:52 PM   #16
91integrags's Avatar
Trader Rating: 22 (96%+)
so far, as well as i know. this is the only motor that will clear the triple at my local track, from a stand still. this motor is a beast. will look for a boot for this thing. will one from a os vspec fit? a friend has one, will try and pick it up today to see if it will fit. thanks again guys for your input.
91integrags is offline   Reply With Quote
Old 05-06-2009, 06:33 PM   #17
houston's Avatar
Trader Rating: 91 (100%+)
Originally Posted by 91integrags View Post
ok guys, dunked this thing in soapy water. no leaks at the front bearing, rear cover, head button, carb to crankcase area. but there IS bubbles at the carb slide. i noticed that the slide has a small canal on the shaft throughout, and a slightly larger canal on the shaft when pulling the slide out farther. is this for lubrication of the slide? is it normal to have some leaking in this area?
i do have a small tear on the end of my boot. will changing the boot completely clear my problem?
i have bought a novarossi p5x carb here, just to try out on the extech. which carb insert should i run on this carb?
try the 8mm
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 05-06-2009, 07:43 PM   #18
ok. used some rtv to seal up the carb boot area. will let it set overnight. will try an retune the motor tommorrow. the tear was just 1mm long. hope the rtv will help. if this doesnt work. will wait on my nova carb to come in.
Old 05-06-2009, 08:12 PM   #19
Integra's Avatar
RTV is not fuel proof......you need som Lucky 7 or Racer's Edge carb sealant.
Old 05-11-2009, 08:53 PM   #20
lucky 7 or continue to have problems. It is flexible and will do the job. Had the same problem on my FM Extech 24 too. once you seal it up... good luck controlling it!!
bottomline2000 is offline   Reply With Quote
lrp brushless esc raceblast Electric On-Road 840 04-02-2012 04:45 PM
XRC 1/5 SCALE CARS brewer Australian Racing 3474 01-25-2011 03:10 AM
Go Tech Engines pino Onroad Nitro Engine Zone 331 08-04-2009 08:39 PM
Sealing a motor piranha21 Nitro Off-Road 61 06-20-2009 06:58 PM
twin mp777 now even more power chris52 Nitro Off-Road 15 07-29-2008 06:01 PM
