Old 05-02-2009, 11:51 PM   #1
omarwashington's Avatar
Default Making your own grease
So I’ve been thinking about making my own grease. Basically from what I read on some high quality rc greases, the two main ingredients are …lithium grease and synthetic oil. So why not mix the two, maybe 4 parts grease and 1 part synthetic oil and maybe mix in a little wd40.
I plan on using this as an all purpose grease which will be used for ball bearings and diff out drives etc.
I just hope this will not eat up the o rings when building shocks
RCCARS!
omarwashington is offline   Reply With Quote
Old 05-03-2009, 08:42 AM   #2
Suspended
It's one of those things, why reinvent something if it already exists? Most of the greases we use for the hobby are specialized for a specific task i.e. green slime for shocks, clear grease for ball diffs, high pressure black grease for thrust bearings, Tamiya Anti-wear grease for out drives and CVD's. It would be impossible to make a grease that works as well as all the specialized greases for their specific purpose. There are other things to consider, one of which you touched on (shock seals). How will your grease effect the parts you put it on. Will it make plastic brittle? Will it eat bearing and shock seals? Your best bet is to stick to the greases that already exsist. The reason people usually make something themself is because it doesn't exsist, or is really expensive. Specific greases fall into neither of these catigories. It's just easier to buy the stuff that already exsists, than trying to reinvent the wheel.
Either way good luck.
R.I.P. Grimace360
ifuonlyknew is offline   Reply With Quote
Old 05-03-2009, 12:33 PM   #3
It might be fun to test with this stuff at practice sessions, but I'd run what I know works on race day. Let us know what you come up with.
CarCrazy is offline   Reply With Quote
Mugen MBX6 teeforb Nitro Off-Road 18539 03-20-2016 02:59 PM
Kyosho VoneR Thread neons Nitro On-Road 12206 06-29-2012 03:19 PM
XRC 1/5 SCALE CARS brewer Australian Racing 3474 01-25-2011 03:10 AM
Signs that you're addicted to RC Hide Chat Lounge 124 05-29-2010 12:02 PM
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 01:47 PM
