Old 05-02-2009, 07:09 PM   #1
Default Clutch bell?
hey guys
can somene tell me if there should be a little play in the clutch bell and if theres no play but the clutch spins freely is that ok
thanks
john
JHN1 is offline   Reply With Quote
Old 05-02-2009, 07:20 PM   #2
You want some play. You want the bell to have some play on the shaft, as in you can slide it along the shaft approx 2 mm. You also want a little bit of play in the gear mesh, but just ever so slight. I simply slip a piece of paper (about 100 thousands of an inch (.100)) between the bell and spur gear when I am tightening my motor. That usually works pretty good for setting gear mesh.
If you truly have NO play on the clutch bell, I would check your shims. It is possible you can simply remove a shim and be set. If you are using no shims, double check and make sure the bearings are not bound a little in the bell. Push on the bell hard to make sure the bearings are seated all the way.
Hope this helps.
Larks is offline   Reply With Quote
Old 05-04-2009, 04:37 AM   #3
cweb's Avatar
Trader Rating: 35 (100%+)
Hope this helps.
2mm of play just a tick of play in the clutch bell is fine. just as long as it doesn't bind on you. P.S. get some tko conical washers if you don't have some, they are the best clutch washers IMO.
Team Whiteknuckle- CW
B5M- viper-rc/Hitec/avid/schelle/mip/protek-rc/lunsford
T5m- viper-rc/Hitec/avid/schelle/protek-rc/lunsford
cweb is offline   Reply With Quote
Old 05-04-2009, 05:23 AM   #4
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
+1 2mm!!!! Ummm... not NEARLY that much. You should be able to move it just slightly, maybe the thickness of 1 shim.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Mugen MBX6T Mugen9112 Nitro Off-Road 8494 04-12-2017 12:03 PM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 07:17 AM
The Nitro Pit Dbackmasta Arizona-New Mexico Racing 18732 09-13-2012 08:27 AM
New 1/8 on-road "XR8" dino.tw Nitro On-Road 966 07-11-2011 11:57 PM
Unscrewing the pinion gear from clutch bell PrimeAKF11 Nitro On-Road 6 07-11-2009 09:17 AM
Losi Muggy question DHC6 Nitro Off-Road 9 03-17-2009 12:37 AM
