Old 05-02-2009, 05:00 PM   #16
Akhor's Avatar
Losi
--Blaine--
VBC D07, VBC D08
Mugen MBX 7, Mugen MBX 7 Eco,Mugen MBX 7r, Mugen MBX 7r Eco
www.rcgears.net, www.carcar.ca, www.karz.ca
Akhor is offline   Reply With Quote
Old 05-02-2009, 06:41 PM   #17
B.A. Racer's Avatar
its pretty even
Brad Abtey
Team Associated | Reedy | JConcepts | Infamous Designs | PitBox Hobbies | Shady Apex
"Anything in life worth doing, is worth overdoing."
B.A. Racer is offline   Reply With Quote
Old 05-02-2009, 11:33 PM   #18
wstuart's Avatar
Trader Rating: 112 (98%+)
Send a message via AIM to wstuart
so far I would say LOSI 2.0
I raced an RC8 for about a year. I knew the guy who designed the new shock towers for AE, So I had everything the new rc8b has (steering mod and bb and shock towers). I Just got a 2.0 losi and my first race was JBRL RD1.
what I think.
RC8
- better steering off power, good steering on power but kind of hard to drive. Car could really rotate on power (if you're good at driving like this the get the rc8)
If you like to throttle through the corners and drive "hard" this is the car for you.
Lots of durability issues though - broke lots of stuff - had to threadlock everything
Losi, steering not as tight but WAY more predictable and easier to drive ( wont snap around on you)
- makes you have to set up for corners more though.
way better through the air and through the whoops - it takes alot to flip this car over. I had to do the battery mod and alot of work with the AE shocks to try to make it jump half as well as the LOSI
the more conservatively you drive it the faster it goes - seemed like it carries momentum more through the track - I felt like I was using alot less throttle and was steering the car rather than driving it - if that makes sense.
Durability, - Ive only had one race day so cant really say , but absolutely nothing came loose and if anything the car feels better than when I first got it. I like it so far.
Im more of an onroad racer so I try not to use throttle to rotate my car , I try to set up for the corners more and use momentum - for my style I like the losi alot better. I was very tired of trying to keep up with all the mods for the rc8 too. On the LOSI, the box stock setup is dialed. I feel like I can spend more time thinking about driving and less about setup
Yokomo Yz-2 x2
Yokomo B-max4iii
Awesomatix a700 evo
Team El Cajon Hobbies
wstuart is offline   Reply With Quote
Old 05-03-2009, 06:48 AM   #19
Integra's Avatar
Well said wstuart.
Old 05-03-2009, 10:23 AM   #20
HaulinBass's Avatar
I find the Rc8 DOESNT like to be driven with a heavy finger, the rear end tends to penduellum or swap ends when driven like this.
HaulinBass is offline   Reply With Quote
Old 05-03-2009, 10:35 AM   #21
SuperSmoove's Avatar
Im a losi fan for sure, but i got an RC8 the other day and have yet to try it. Anyone wanna buy an rc8?
SuperSmoove is offline   Reply With Quote
Old 05-03-2009, 11:08 AM   #22
B.A. Racer's Avatar
lol how much super smoove
Brad Abtey
Old 05-03-2009, 08:43 PM   #23
Jube's Avatar
Trader Rating: 43 (100%+)
What setup are you running? It can be adjusted to point and shoot.
Jubal Dike
X-Factory www.xfactoryrc.com | Tekin www.teamtekin.com | Panther Tires www.panthertires.com | DE Racing www.deracing.net | Avid www.avidrc.com | Coyote Hobbies www.coyotehobbies.com | 411 Graphics
Jube is offline   Reply With Quote
Old 05-03-2009, 09:47 PM   #24
HaulinBass's Avatar
I run maifields world setup with 18 degrees caster, long rear link, silve front bar, kyosho 2.3mm front bar on rear.kyosho 7k front diff 5k center,5k rear. I tried the rear hubs in the upper roll center hole that made the rear grab to hard going side to side. Im trying heavier rear fluid in the diff and going with the upper hole for the rear upper arms my next trip to the track.
Old 05-03-2009, 09:51 PM   #25
tc5 man's Avatar
jub u know what setup for the losi eight 1.0 for point and shoot i used to that in 2wd gas truck
Old 05-04-2009, 06:10 AM   #26
Jube's Avatar
Have you tried going to 2 or 3k weight in the rear? That would certainly help. Going heavier in the rear will give it more of a "spool" effect and just cause it to dance even more.
Jubal Dike
Old 05-04-2009, 06:11 AM   #27
Jube's Avatar
? huh? lol
Jubal Dike
Old 05-04-2009, 08:08 AM   #28
PTP Racing's Avatar
I had the 8ight 1.0 when I got the RC8. I took both to the track with pretty much equal equipment and used the same tires on both cars and ran qualifiers with each back to back. I ran my fastest lap with the Losi and the fastest qualifier with the RC8. Keep in mind I had dailed the Losi in already and was using the stock set-up on the RC8. At the end of the day I couldnt say which was really better than the other but knew I had to let one go because switching back and forth was not feasible.
I offered both for sale and took the first deal that came along. The 8ight was sold and I kept the RC8.
Since then I have made many improvements to the RC8 both in set-up and with hop-ups like big bores that werent available when I originally tested back to back. I have done extremely well with the RC8 and when I drove a friends 2.0 when they were released I still prefered the feel of my RC8 although admittedly the 2.0 was still good.
I feel the biggest difference between the cars IMO is the way you have to drive the Losi. I felt like I could really push the RC8 much harder. I could run good laps with both but if I got trigger happy with the 2.0 I would overshoot jumps and the back end would get loose.
I'm not going to say one is better than the other. Nobody can know for sure which is best for you. If you dont like your RC8 then maybe switching will be good but if you do like the RC8 I would stick with it at least until you can try the new parts on it. You wouldnt be able to get much for it right now if you were to sell it but with the new parts installed if you wanted to sell the resale would be much better.
I think about this a lot myself and there is one thing that really bugs me about the Losi and that is the carb angle. On the 8ight I had and even the 808 I had problems with the carbs sticking. I'll admit it has to be partially user error on my part but I tried every trick I could think of and still had problems.
Paycheck to Paycheck Racing
Jason Miller
PTP Racing is offline   Reply With Quote
Old 05-04-2009, 08:16 AM   #29
LOSI
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 05-04-2009, 08:28 AM   #30
Get a mugen mbx6.I have had all of the cars. The losi and Mugen drive very much the same but the Mugen is better quality. The rc8 is a still fragile IMO.
Thopper is offline   Reply With Quote
Helical vs. straight cut diff gears???..... ganymede Nitro Off-Road 48 05-29-2011 09:18 AM
RC8e vs. 8ight-e 2.0 JATOdriver Electric Off-Road 19 08-15-2009 01:31 AM
losi 2.0 vs. mp9 patrick lsp Nitro Off-Road 53 04-11-2009 03:42 AM
What buggy? HB D8 or Losi 8v2? Xchange Nitro Off-Road 67 02-13-2009 01:36 PM
8ight 2.0 vs 808 vs O'Donnell jpas Nitro Off-Road 66 10-14-2008 09:31 AM
LOSI 8 OR ASSOCIATED 8 which is BEST? Xray prince Nitro Off-Road 68 12-06-2007 09:43 PM
