Futaba S9351 parts are $$$$$
Hi all, I have a S9351 servo that I was using in my Losi 8 and one of the ears broke off and there is a crack in the side of the top plastic part. Does any one know (or have) were I can purchase just the top part of the servo, other wise it's $45 for all 3 components witch is just silly if all I need is the top..
Thanks....
Thanks....
Does anyone know if that case will work for the S9350 servo? This is kind of hard to explain what happen....On the servo top case, in the works of the servo gears, there is this plastic supoorter (or whatever you call it) thats holds the pin on. Well the plastic thing cracked and then split off so the servo would not mvoe right because the gears would mvoe inside. I seen the price-$45 and all I did was shoo goo it, then let sit till hard.
R/C Tech Elite Member
