Old 05-01-2009, 09:03 AM   #1
TRIPC's Avatar
Default Whats a easy way to get carb off VSPEC.
I have a fairly new VSPEC with the new Carb. It wont come off. What some ways you guys take the carbs off??
Losi 8B OS V-Spec/Ex-Tech/Novarossi
Losi 8T OS V-Spec (in the works)!
Spektrum DX3S
TRIPC is offline   Reply With Quote
Old 05-01-2009, 09:08 AM   #2
Jaz240's Avatar
Trader Rating: 52 (100%+)
Make sure the pinch bolts are really loose and then just twist the carb slowly back and forth, while gently pulling upwards. It's not glued in there. Work it, it will come free
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 05-01-2009, 09:10 AM   #3
SkarTisu's Avatar
Send a message via AIM to SkarTisu Send a message via Yahoo to SkarTisu
You could hit the crankcase with a heat gun as well to get things to expand just a touch. USE GLOVES!
Marshall Skare
Team Associated - Reedy Powered - JConcepts - LiveRC.com
SkarTisu is offline   Reply With Quote
Old 05-01-2009, 09:39 AM   #4
Mack_Mechanic's Avatar
J/K,Jaz and Skar have the right ideas.
Steve Arms
www.rcracebarn.net
There is no such thing as too much motor....just not enough driver!
Mack_Mechanic is offline   Reply With Quote
Old 05-01-2009, 10:07 AM   #5
pinky2252s's Avatar
Send a message via AIM to pinky2252s Send a message via MSN to pinky2252s
http://images.businessweek.com/di/id...2007/fubar.jpg
Procrastinators Unite!.....Tomorrow
Team Terribles
pinky2252s is offline   Reply With Quote
Old 05-01-2009, 11:46 AM   #6
l3asher's Avatar
After the screw is loose, hit the end on the driver (with it still in the screw) a little and it will break it loose.
l3asher is offline   Reply With Quote
Old 05-01-2009, 11:58 AM   #7
Waters's Avatar
when you go to put it back together make sure that when you tighten the pinch bolt you tighten it up and then another 180. you don't want it to tight or you will crush the plastic sleeve to the point that it will crack, and that is bad..
$12 to replace been there done that...
Losi 8b 2.0, Werks B5 2057, Losi 8bE 1.0 2200kv 3s 7-12 ounces, T4.1, B4.1,
Waters is offline   Reply With Quote
