Old 04-30-2009, 08:36 AM   #1
Default Servo going
I am relatively new to the hobby. I have an 8ight RTR Truggy. The steering servo still works but it seems quite slow to move. When it does move it moves with some force.....just slowly.
Is it common for a servo that is going bad to go bad in this way?
Thanks.
rav_cherry is offline   Reply With Quote
Old 04-30-2009, 08:38 AM   #2
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Are your batteries all charged up? I guess that could be a symptom of a bad servo, but could also be a weak/bad reciever battery.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 04-30-2009, 08:50 AM   #3
scwrod's Avatar
Is it just slow while truck is sitting still on the ground? It may just seem slow while the truggy is on the ground and not moving.
hbracing.com tritonrc.com raceaka.com
scwrod is offline   Reply With Quote
Old 04-30-2009, 09:23 AM   #4
Thumbs up
Also check your servo saver spring for tightness. Its very common to have that spring get soft and need tightening. Check steering rack for free movement by taking the servo arm off, and actuating the steering rack. It should be really free and easy to move.
Steering issues:
1 Check Battery
2 Check Servo Saver
3 Check to make sure servo arm isn't rubbing on the servos top.
4 Check steering rack for free/easy movement.
5 Could be a servo issue...
CarCrazy is offline   Reply With Quote
Old 04-30-2009, 09:31 AM   #5
First of all the steerin servo in the RTR truggy - sucks- its not enough power to turn the wheels while stationary and I will not last long.........
I would suggest ACE, Hitec, or JR servos and at lease 200oz
If it turns while your driving - this is the problem
If it dont turn while your dirving - check the saver spring and bearings
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 04-30-2009, 04:21 PM   #6
Everything is charged...not sure how to check the bearings/spring. There is a bit of play in the arm when at rest. It doesn't want to turn on the track at slow speeds and when I am breaking hard into a corner.
Old 04-30-2009, 05:26 PM   #7
boostfiend's Avatar
My servo did this to me last weekend. I had stripped all but two teeth off the gear coming directly off the motor. It turned, but very very slowly. My servo saver was adjusted WAY too tight, so the only plastic servo gear took the force.
When you do replace the servo, get the best you can get. I went from using an Ace DS1313 to a Futaba BLS451 - the difference is night and day. The Futaba is just SO GOOD! Certainly worth the extra 40 bucks.
boostfiend is offline   Reply With Quote
Old 05-01-2009, 05:45 AM   #8
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Spend the $100-$120 for a GOOD steering servo. I personally like Hitec (like the 7995TG, which is the "newer version" of th 5995TG that I currently run) but there are a lot of good ones... Futaba, Ace, Hitec...
Get something with at least 180 oz of torque and metal gears (or in the case of the Hitec it has titanium gears.)
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Trackside Matt M. Wisconsin & Illinois Racing 17044 01-20-2017 09:34 AM
New Traxxas Slash 1:10 Electric CORR Truck salteen Electric Off-Road 3949 03-19-2012 08:24 AM
BEST LOSI 8B UPGRADES? levi m Nitro Off-Road 15 03-21-2008 10:53 PM
New Servo not quite right...help Stoffa Electric On-Road 15 07-16-2006 02:11 AM
XXX-S Graphite and LOTS of other items jfischer R/C Items: For Sale/Trade 6 03-07-2006 04:11 PM
Weird handling discussion... black-knight Australian Racing 37 02-06-2005 03:14 PM
Bulletproof your G4 Steering (How-to) KMac Nitro On-Road 37 04-04-2004 05:52 AM
