Old 04-29-2009, 11:47 PM   #1
wstuart's Avatar
Trader Rating: 112 (98%+)
Send a message via AIM to wstuart
Default 8ight T 2.0 Offset question
Im running an 8ight 1.5 (2.0 body and chassis and 1.0 everything else)
ive been told that I can run standard wheels hubs with losi wheels but with aka wheels I need to run the +1/2 inch hubs.
Why is this.
Is it because the AKA wheels have a standard offset.
Yokomo Yz-2 x2
Yokomo B-max4iii
Awesomatix a700 evo
Team El Cajon Hobbies
wstuart is offline   Reply With Quote
Old 04-30-2009, 03:27 AM   #2
air8's Avatar
Since you haven't changed the arms, linkages, and steering components to the 2.0 yet, the 1/2" offset rims is what you want. The zero offset wheels will rub too much on the arms and linkages with the 1.0 parts still on there. AKA now has zero and 1/2" offset wheels out.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 04-30-2009, 08:04 AM   #3
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
I don't think AKA has 1/2 offset wheels out. Where did you see this?
As for your question, yes you will need to run either 1/2 offset wheels, or 1/2" extended hubs. Running zero offsets on the 1.0 suspension would make your track width very narrow, and cause binding problems like air8 said.
Here are the extended hubs you will need. The losi ones are cheaper, but the KHZ ones are a lot nicer because they capture the drive pin with a big O-ring.
http://carolinasrc.com/Webstore/Scri...idproduct=5246
http://carolinasrc.com/Webstore/Scri...idproduct=4252
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 04-30-2009, 12:11 PM   #4
wstuart's Avatar
Do the losi wheels come with 1/2 inch offset?
Yokomo Yz-2 x2
Yokomo B-max4iii
Awesomatix a700 evo
Old 04-30-2009, 12:20 PM   #5
hambone's Avatar
Losi has both 1/2" and zero offset rims. So do other manufacturers like proline for example. You need 1/2" offset LPR sized rims.
Rob Hamm
The Nitro Shop
Bones Motorsports
Answer-RC/TLR/Futaba
Snow Monkey Racing
hambone is offline   Reply With Quote
Old 04-30-2009, 02:50 PM   #6
wstuart's Avatar
Cool - thanks for all the help guys.
So I have a set of Losi truggy wheels but I dont know what offset they are - is there any way I can tell?
Yokomo Yz-2 x2
Yokomo B-max4iii
Awesomatix a700 evo
Old 04-30-2009, 03:03 PM   #7
Yup. The way you can tell them apart is where the wheel mounts. ie where the hex/wheel nut sits. If it is just about flush with the face of the wheel it is zero offset. If it is recessed 1/2 of the way through the wheel, it is 1/2 offset.
These are zero offsets...
http://carolinasrc.com/Webstore/Scri...idproduct=6608
These are 1/2 offset....
http://carolinasrc.com/Webstore/Scri...idproduct=6220
Click the pictures for an exploded view. See the difference?
-Koby Kubrin-
Old 04-30-2009, 03:22 PM   #8
wstuart's Avatar
ooooh - awesome. thats makes alot more sense now
Yokomo Yz-2 x2
Yokomo B-max4iii
Awesomatix a700 evo
Old 04-30-2009, 08:29 PM   #9
air8's Avatar
I guess I was wrong. I went back through the news on Neobuggy and it must have been the VP Pro wheels I was thinking of.
Sorry for mis-leading anyone that AKA has 1/2" off-set wheels.
--"U Ain't Fast!!"
Chris Pearce
Old 04-30-2009, 09:11 PM   #10
It's cool man. I was actually curious to see if I was wrong. They do need to make some 1/2 offsets.
-Koby Kubrin-
Old 05-01-2009, 01:14 AM   #11
air8's Avatar
Agreed.
--"U Ain't Fast!!"
Chris Pearce
