Old 04-29-2009, 10:19 PM   #1
Default Had an Accident
My brother got a new savage xl today, we broke it in nice and then took it for a burn. The first run the air filter must have come off and the engine stalled in a giant cloud of very thick dust.
Once i seen this we took the pipe off the back, glowplug out, and blasted 1/2 a bottle of nitro engine cleaner in there flushing the engine out. When i moved the piston by hand i could hear the grit in there, so i oiled it up with after run and did my best to clean the majority of it out.
I put a new glowplug in, set the high speed and low speed back to factory and ran it at idol for a tank a fuel. The exhaust was a little brown for a bit but it went clear again. After that we tuned it as normal and ran it, all went well.
My question is, how can we tell how much damage we did? I looked inside and it looked fine as i could tell, but im no expert.
Thanks.
xikron is offline   Reply With Quote
Old 04-29-2009, 11:45 PM   #2
RCmayor's Avatar
Send a message via Yahoo to RCmayor
It probably would have been better to take the engine out and pop the backplate off then clean it out thoroughly. As far as damage, probably some, but if it is running then it should be ok. You probably took some life out of it though and some performance also. At least the filter problem was caught early. Worst case you will have to put a new Piston/Sleeve in it ,and maybe a bearing, sooner rather than later or just get a new engine.
RCmayor is offline   Reply With Quote
Old 04-30-2009, 12:02 AM   #3
keavze's Avatar
better to strip down the engine for a thorough check and cleanup.
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 04-30-2009, 11:03 AM   #4
i had an issue where the airfilter came off and like you i could hear/feel the grit in the motor. i disassembled the motor and the piston and sleeve were in good condition. The issue was the bearings. they were what i was feeling. i was fortunate enought to be able to flush them out and make them feel smooth again. without taking it apart i feel the bearings would have destroyed themselves shortly. I keep it as a spare motor but it has over a gallon run through since this situation.
stevef is offline   Reply With Quote
Formula 1... Darkseid Chat Lounge 14873 08-17-2017 03:44 AM
Rc10ntc3 Taz_S Nitro On-Road 9437 05-28-2017 08:13 PM
RC FLIGHT brading Manila Racers 23110 12-24-2015 06:23 PM
US Indoor Champs 2006 MR.BILL Electric On-Road 1269 12-10-2006 08:47 AM
FSEARA Race 3 Superior Hobbies Apr 22-23 TimPotter Florida Racing 175 05-08-2006 02:05 PM
Proton Gen2:What do u think about it? HyperSpeed Malaysian R/C Racers 75 03-26-2004 06:30 AM
