Old 04-28-2009, 08:16 AM   #1
jhipps835's Avatar
Trader Rating: 13 (88%+)
Default Losi 8ight rtr engine
Is the engine in the original losi 8ight rtr buggy a .21?
Or what size is it?
jhipps835 is offline   Reply With Quote
Old 04-28-2009, 08:17 AM   #2
pballer2777's Avatar
Trader Rating: 27 (100%+)
tlr 8 4.0 /rex engine/aka
tlr 8e 3.0/tekin/aka
pballer2777 is offline   Reply With Quote
Old 04-28-2009, 08:33 AM   #3
l3asher's Avatar
I would of said a 27 since in was a mach 427.
Who would of knew.
l3asher is offline   Reply With Quote
Old 04-28-2009, 08:41 AM   #4
BAUSTIN's Avatar
Who would of knew.
not that it matters......but i think you are right.....
Mach 427 with Pull StartS SG Crankshaft
Key Features
4.27cc displacement
ABC piston/sleeve assembly
Dual-needle carb
Overview
This high tech power plant includes a dual needle carburetor and race proven porting for an excellent balance of torque and top speed. It also features a black case and oversized orange heat sink head to keep things cool. The Mach 427 can be dropped into just about any 1/8-scale truck or buggy for intense performance.
Specs
Type:2-Stroke
Displacement:.27
Bore:18mm
Stroke:16.75mm
RPM Range:Up tp 28,000
HP:2.85
Front Bearing Size:7x19x6
Rear Bearing Size:13x24x6
Cylinder Type:ABC
Starting System:Pull Start
# of Ports:7
Carb Type:2 needle slide
Crank Type:SG
http://www.horizonhobby.com/Products...ProdID=DYN0895
Billy Austin
www.Code3RC.com
Elevation Sports
BAUSTIN is offline   Reply With Quote
Old 04-28-2009, 08:46 AM   #5
markr04's Avatar
It is a .26.
The 427 stands for 4.27cc. Converted to ci, it is .26.
Also, the box that it ships in:
Xray 808 2010 Spec - O.S. V-Spec Speed - Airtronics M11-DSSS
Losi 8ight-T 2.0 - RB Killer 9 - Airtronics M11-FHSS-2
Losi XXX-CR - Tekin RS / Novak Ballistic 13.5 - Airtronics M11-FHSS-2
markr04 is offline   Reply With Quote
Old 04-28-2009, 08:50 AM   #6
BAUSTIN's Avatar
i agree.....i guess its just a marketing thing......
the 427 box i have is gold and just says Losi on it...ahh ic that is the "dynamite"....box.....
Billy Austin
www.Code3RC.com
Elevation Sports
Old 04-28-2009, 10:46 AM   #7
The new one is a .21...the rtr that comes with the starter box etc.
Thopper is offline   Reply With Quote
Old 04-29-2009, 05:23 AM   #8
air8's Avatar
markr04 and Thopper are correct.
The 1.0 Losi 8ight and 8ight-T RTR's both used the Mach 427 which is .26 cubic inch.
The new 2.0 8ight RTR uses an engine called the 350(.21) and 8ight-T RTR uses the 454(.27) If these new perform like the Mach 427 7 port they will be awesome engines. That Mach 427 is still awesome and priced perfect.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 08:43 AM
Broke my leg and selling off all my rc car stuff larryh37wi R/C Items: For Sale/Trade 17 04-13-2009 05:10 PM
RC8 RTR vs Losi 8ight RTR vs Jammin X1 RTR sidewaze Nitro Off-Road 30 12-30-2008 06:23 AM
8ight kit/roller starter boxes Jonro Nitro Off-Road 7 05-30-2008 01:23 AM
Dynamite MACH 427 for sale 8ightTJ R/C Items: For Sale/Trade 6 05-17-2007 06:24 PM
