tuning issues
Ok well, I was out today in 68* weather running my .21 OS v-spec and I tuned the low end pretty well, and the highend (I think). The problem is, when I'm full throttle, then let off the gas completely, it will high idle and coast for about 2-3seconds, then it returns to normal idle. any idea?
Low speed to rich
Lean you low speed then check your high speed |
thanks I'll give it a shot. Previously when I started to lean out the low end, my idle got higher and the car wanted to coast at idle...
You were going in the right direction. Just lower your idle and you'll be fine.
Sweet, ok I'll do that thank you! :nod:
No problem.
