Old 04-27-2009, 07:12 AM   #1
slaytanic's Avatar
Trader Rating: 20 (95%+)
Default Heatshrink on cvd's
I was breaking in my XT8 this weekend and forgot to locktite the set screws for my center cvd pins. So they fell apart. No biggie. It got me thinking about maybe putting some heatshrink on them so if it does come loose the heatshrink would keep the pin in long enough to finish the heat. Anyone try this or have a better idea? I know about cvd boots but I think the XT8's are to big for these.
Team Epic
Team Terribles~Answer RC~Fastlane Graphics~Torco Race Fuels
XB808 Mamba Max Pro/Tekin 1900kv RC-monster mount and tray 4s
XT8 Hobbywing 150a esc/2000kv combo KILLER! Full rc-monster e conversion. 4s
slaytanic is offline   Reply With Quote
Old 04-27-2009, 07:18 AM   #2
markr04's Avatar
You know what... that sounds like a good idea!
Alternatively, electrical tape may also work.
Xray 808 2010 Spec - O.S. V-Spec Speed - Airtronics M11-DSSS
Losi 8ight-T 2.0 - RB Killer 9 - Airtronics M11-FHSS-2
Losi XXX-CR - Tekin RS / Novak Ballistic 13.5 - Airtronics M11-FHSS-2
markr04 is offline   Reply With Quote
Old 04-27-2009, 07:23 AM   #3
Davidka's Avatar
Trader Rating: 75 (100%+)
This works ok temporarily but the heat shrink material isn't very durable. If the pin/barrel comes loose then the pin wears throught the heat shrink fairly fast so you still have to keep an eye on it.
Old 04-27-2009, 07:39 AM   #4
Regional Moderator
marccaracer's Avatar
Losi's have plastic boots around theirs. Maybe they would fit?
Jeff Mann
marccaracer is offline   Reply With Quote
Old 04-27-2009, 07:49 AM   #5
slaytanic's Avatar
I guess the downside is that you would have to cut it off to check it. And then do some dissassembly to reinstall. I think the rubber would keep dirt out but not really do much to keep the pin in place for a short time. I thinking of it as a backup incase of setscrew failure/backing out. I would worry about electrical tape come unraveled at in a race and wreaking some other kind of havoc.
Team Epic
Old 04-27-2009, 07:53 AM   #6
Davidka's Avatar
Someone (TKO, King Headz, M2C..) made some very nice spring steel collars to correct this before on the Losi. The GMK vinyl things were cheap and worked so the metal ones never gained popularity. I guess this is a fairly new problem, we didn't used to need these but even the rear on the Losi would come apart and that shaft runs so straight it barely needs a uni in the first place.
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 05:09 AM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 07:38 PM
OCM Racing KOAS DT-19 LKH Malaysian R/C Racers 399 01-09-2013 06:07 AM
HPI Racing Cyber 10B wagonman72 Electric Off-Road 332 07-01-2011 09:33 AM
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 08:43 AM
Ofna GTP carguy Oval, Larger Scales and More 62 10-29-2008 06:36 PM
