Old 04-26-2009, 03:31 PM   #1
mamba4life's Avatar
Trader Rating: 23 (96%+)
Send a message via MSN to mamba4life Send a message via Yahoo to mamba4life
Questions?? seal?
Which parts of my nitro motor should i be sealing?? and with what??
i have 2 new motors should i seal before break in?? ? or wait till it f**ks me on race day???? Help new racer please!
should i be rebuilding my motor apart alot or only when it breaks?? ???
Slow and low ,
mamba4life is offline   Reply With Quote
Old 04-26-2009, 04:01 PM   #2
Typically, you would seal the backplate and carb neck with engine sealant.
Team HRC Raceway - http://www.hrcraceway.ca/
Semple is offline   Reply With Quote
Old 04-26-2009, 04:08 PM   #3
cary's Avatar
Trader Rating: 67 (100%+)
when i get a new mottor i will take it apart inspect it
lube it up with after run oil seal the back plate with
racers edge engine sealent
Xray XB8 14,AE RC8T3,XB9 13,Kyosho wheeler,Losi SCTE 2.0,+ More
> The Animal,Frank L. Jr. <
~~~~RedRock Hobbies~~~~
cary is offline   Reply With Quote
Old 04-26-2009, 04:10 PM   #4
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
You should seal your engine before break-in. Setting up a new engine in a car I always mock up the alignment of the carb with your linkage, take the engine back out, then seal up around the HS needle assembly, pinch bolt ends, and base of the carb where it meets the case/block. Lucky7Rc engine sealant is designed for just that purpose.
http://tkocompetitiondev.com/index.php?cPath=38_114
http://www.amainhobbies.com/product_...ducts_id/25728
Lucky 7 Rc Engine Sealant for nitro engines is a quick dry wicking air seal which doesn't require engine disassembly. If your nitro engine has an air leak around the neck of the carburetor, or the needle valve assembly, it can make the engine run erratically and change from lean to rich conditions. To avoid this problem it is always a good idea to seal up the carburetor around the neck and needle valve assembly, and this sealant is excellent for that purpose. You can also use it to seal the back plate of your engine to avoid air leaks around the back of the engine as well.
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 04-26-2009, 06:01 PM   #5
Trader Rating: 19 (100%+)
For mine i only do the backplate but thats because the mills I run have o-rings in the throat of the carb where it seats and at the top of the neck. But after a while I have been known to throw a dab around the neck of the carb you can just to be shure and use the lucky 7.
TT MT4G3 all tricked
TTST4G3 MT4ed out
JR servos Hitec servos. Gens ace lipos KO radio.
malik is offline   Reply With Quote
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 01:50 PM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 07:19 AM
RC knowledge sharing catkchun Malaysian R/C Racers 79 10-18-2007 06:31 PM
How do you clean and tune your ball bearings? jaykay Nitro On-Road 17 01-08-2007 09:39 PM
