Old 04-26-2009, 06:21 AM   #1
Krawl's Avatar
Default How To Clean Carbon Deposits On The Piston Head?
My V-spec piston was squeaky clean after break-in process, then I did the after run routine on the next gallon, the piston starting to get blackened by carbon deposits, is this normal? Or it's should be clean? How to clean this? I run my vspec average on 70-90 degrees celcius. Thanks.
HPI Blitz EZRUN 60A + 6000kv + 2S + 4000mAh 25C
Jammin SCRT10 XERUN 120A + SP Silver Arrow V10 3.5R + 2S + 5800mAh 25C
Krawl is offline   Reply With Quote
Old 04-26-2009, 07:57 AM   #2
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
A little carbon build up is normal. A lot of carbon is signs of poor fuel. Carbon will clean off with after run oil.
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 04-26-2009, 08:18 AM   #3
madmaxx's Avatar
for the stubborn stuff i use automotive carb cleaner sprayed into a rag and rub it off, seem's to have worked for me so far....
YOU CAN'T HANDLE THE TRUTH!
>> http://ca.geocities.com/jleblao/ <<
^^MC carbon custom carbon fibre REVO part's!^^
madmaxx is offline   Reply With Quote
Old 04-26-2009, 09:02 AM   #4
i use Tamiya Polishing Compound to remove such, seems perfect for me, but remember just the top part, not the surface of the cylinder.
rcpeople is offline   Reply With Quote
Old 04-26-2009, 11:20 AM   #5
Krawl's Avatar
I've seen some mechanics uses metal polish to clean the piston and wondering if that will reduce the compression of the engine since that is abrasive...
Old 04-26-2009, 11:42 AM   #6
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
You can clean the top of the piston & head button ONLY. IMO, I don't bother with the cleaning. Carbon will always show up on a race tuned engine. It does nothing to the engine at all. You'll actually find that if you keep cleaning that motor, it will not run or perform well in the long run. Inspection of rod bushing and bearings is about the only thing needed.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 04-26-2009, 12:01 PM   #7
asw7576's Avatar
I use metal polish.
Clean and polish only the top of piston head and button head.... and leave the side alone. I also use dremel with soft tip ( cloth tip ) to polish it.
Don't forget to clean spray and re-oil the piston unit and button head before putting them back in into engine.
Old 04-26-2009, 12:09 PM   #8
Krawl's Avatar
But don't you think that carbon build up will eventually slippin' into the sleeve and make some scratches? Or it will messed the combustion chamber?
Old 04-26-2009, 12:45 PM   #9
asw7576's Avatar
Carbon build up on the piston ring, is good thing, it is acting like a piston seal. It wont scracth the sleeve liner.
Carbon build up on top of piston and underneath the button head, they are not good. In severe conditions, the build up could cause pre-detonations, thus increasing the engine temperature.
Old 04-26-2009, 02:13 PM   #10
ezveedub's Avatar
I find high milage engines have lots of top carbon. If you clean this off completely, the will run differently. I just remove heavy or thick pieces, but in a fully race tuned motor, this will just not be there. Only engines that are worn out will start to build up excessively.
