Old 04-25-2009, 07:25 AM   #1
Default braking at full throtle?
when i open up the carb all the way at full throtle, it applies the brakes. It seems no matter how much i adjust it it still pushes the needle (not the carb needle the one that is atatched to the brake pad). Anybody else have this problem?
dreaux is offline   Reply With Quote
Old 04-25-2009, 07:28 AM   #2
markr04's Avatar
Xray 808 2010 Spec - O.S. V-Spec Speed - Airtronics M11-DSSS
Losi 8ight-T 2.0 - RB Killer 9 - Airtronics M11-FHSS-2
Losi XXX-CR - Tekin RS / Novak Ballistic 13.5 - Airtronics M11-FHSS-2
markr04 is offline   Reply With Quote
Old 04-25-2009, 07:28 AM   #3
madmaxx's Avatar
you linkage/servo horn is set incorrectly, gonna have to play with it untill you get it right
YOU CAN'T HANDLE THE TRUTH!
>> http://ca.geocities.com/jleblao/ <<
^^MC carbon custom carbon fibre REVO part's!^^
madmaxx is offline   Reply With Quote
Old 04-25-2009, 07:31 AM   #4
markr04's Avatar
Oh, I think I understand what you meant to say.
You have a "cam" which pushes the brake pad against the disc. Your cam is pointed in the wrong direction.
Old 04-25-2009, 09:06 AM   #5
If it works propperly other than that & is assembled like the picture in the manual & the linkage rods on the servo are shimmed propperly so they dont rub hard on the brake rod eyelet then grind the back of the cam. Some brands are real touchy with this,I believe if you look in the tips section at the jammin site chad bradly has a picture & description on how to do it.Basicly grind the back side of the cam off so it cant hit the pad if something is setup wrong & the rods get pushed backwards.
Just make sure everything is setup correctly before you do that.
butch man is offline   Reply With Quote
N.a.s.c.a.r chammond Canadian R/C Scene 9560 08-06-2017 04:38 PM
How to set arc functions? Jynx Radio and Electronics 10 10-19-2011 01:26 AM
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 08:43 AM
