Old 04-24-2009, 05:16 PM   #1
Default EZ Start
I have a traxxas t maxx 3.3 and I am having problems with my EZ start. I just replaced the easy start motor and the wire harness and I am still having problems. The battery in the started itself is fully charged (starts my roommates tmaxx no problem) but the second I push the starter button the motor turns over and then slowly comes to a stop with the battery not even being able to turn the motor over anymore. Like mentioned its not the battery since i could take it over to my roomies truck and start his jsut fine. I have no idea what the problem could be...... Please help
baxtell13 is offline   Reply With Quote
Old 04-24-2009, 05:22 PM   #2
infernus1986's Avatar
Try to spin the flywheel by hand or with a screw driver if its really hard or you cant do it there may be something broken in the engine.
If your truck is brand new have you broken it in yet ?
infernus1986 is offline   Reply With Quote
Old 04-24-2009, 05:30 PM   #3
The spur gear and fly wheel spin nicely. I have had the truck for a few months now and running it. This is just a recent problem.
Old 04-24-2009, 05:42 PM   #4
RC-Crazy's Avatar
Trader Rating: 55 (100%+)
open up the starter to check the gearing, that could be a issue....... the gear.
Go Fast or Go Home.
RC-Crazy is offline   Reply With Quote
Old 04-24-2009, 05:43 PM   #5
Well what it sounds like is the motor is straining and the overload on the ez start is kicking in or the batt isnt powerfull enough what mah is it ?
I would remove the ez start from the engine, try turning the engine with the One way bearing on the shaft you might need to grip it with some pliars.
If everythings ok there i would check that the ez start gear train is ok and theirs no binding there.
If you have another ez start wand i would test it to make sure that's not the problem i had one that would refuse to light the glow plug even tho it said it was working the wands are cheaply made and tend to get screwed up
Old 04-24-2009, 05:47 PM   #6
inside the gearbox, the second gear from the top, the second one from the engine, is very stiff. I put zero friction lubrication and it helped a little but it is still very stiff. Any suggestions?
Old 04-24-2009, 05:51 PM   #7
It's probably on a bearing, which could be shot.
LRP Z.28R - 3
Spur Gear - 0
howtowakeakar is offline   Reply With Quote
Old 04-24-2009, 08:46 PM   #8
Which gear is it ? A B C D
Old 04-24-2009, 08:52 PM   #9
He said second, so either B or C, probably B (second from "top").
LRP Z.28R - 3
Spur Gear - 0
Old 04-24-2009, 08:54 PM   #10
i realized that but he said from the engine and from the motor and theirs 4 gears
figured id make a picture that makes it easyer
Old 04-24-2009, 09:36 PM   #11
Brad.R's Avatar
Trader Rating: 25 (100%+)
yo its flooded. take the glow plug out and try to turn it over. lol. that always works.
Brad.R is offline   Reply With Quote
Old 04-25-2009, 02:18 AM   #12
Flooded.....I wish that was just the problem
The gear that seems to be stiff is gear C.
Old 04-25-2009, 07:32 AM   #13
n10cities's Avatar
Yo....go back and read post #3...
Your arrogance blinds you.....
Losi - Spektrum - Byron's Fuel - Airtronics
Robbie
GSHobby.com
n10cities is offline   Reply With Quote
Old 04-25-2009, 03:05 PM   #14
Brad.R's Avatar
ya he said spur gear. that does not attack to the flywheel it the clutch. the flyfheel [the silver round thingy] see if that turns. if it is the ez-start go with pullstart. thats what i did. that way when u and ur friend go bashing and his magic wand battery dies. you can still run.
Old 04-25-2009, 03:35 PM   #15
That's the one with the half plastic pin built into the ez start case make sure that its not worn or deformed in some way other also if you look closely that half pin has a recess in the other half of the ez start case make sure theirs nothing gunked up and blocking that.
when you put it back together slap a good bit of white grease all over the gears except for the OWB and make sure you dont over tighten the screw thats in the center of the ez start case half's
