Old 04-24-2009, 05:44 PM   #16
j_blaze14's Avatar
Trader Rating: 34 (100%+)
loosen the plug then turn the car on its side or front, finish removing the plug and without setting down the car start the new plug. once snug set down the car and tighten all the way. no dirt can get in.
aGama A8 EVO - Werks B2 - Sidewinder
aGama A8E - TrackStar 150a, 2560kv, 3 and 4 cell
FlySky GT3B, Turnigy HV servos, SKY Lipos
AKA, Proline, Hotbodies Rubber
Elite Performance - HORRC.com
j_blaze14 is offline   Reply With Quote
Old 04-24-2009, 05:49 PM   #17
Nitro$junkie's Avatar
Send a message via MSN to Nitro$junkie
not if your enigine has a putty ramp in side your crank it causes it to swell up and fall apart and little bits go's threw ya engine not a good idear you need a good after run oil for them motors somthing thing like Novarossi after run oil
But if your engine dosnt have a silicon ramp (putty) then WD40 should be ok but a $10 for the good stuff aint that bad keep the WD40 for cleaning the car and making sure the steel parts dont get surface rust on them and only put Fuel and After run in your engine
Futaba
Mugen
Novarossi
Byron's
http://www.hospitalrecords.com
Nitro$junkie is offline   Reply With Quote
Old 04-24-2009, 06:21 PM   #18
houston's Avatar
Trader Rating: 91 (100%+)
blow out around the plug with nitro wash before removing
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Nitro On-Road Addict sa RC Manila Racers 12522 12-27-2015 05:51 PM
Yay Dvx400Rider Nitro Off-Road 7 02-27-2009 08:25 PM
Please Help Muah! Speedjunkyz Nitro On-Road 36 09-05-2008 07:13 AM
