Old 04-23-2009, 10:44 AM   #1
Default engine help
I have an os vzb v spec .21. I cant get it tuned. I went 2 1/2 in from flush on the hsn. 1 1/2 on the lsn, and the metering is flush. It it sound like its bogging, then take off, with lots of smoke. I have leaned both 1/4 turn, the bogging gets worse, then i richen it, it cuts off. I run byrons 30%. I have never had a motor this difficult to tune. I checked leaks in the tank, tubing etc., maybe trash in the carb? Thanks in advance.
rednekdirtoval is offline   Reply With Quote
Old 04-23-2009, 10:56 AM   #2
hambone's Avatar
My v spec on byrons with a 2050 pipe is tuned like this; hsn-2 1/4 turns out from closed, mid- flush to 1/2 turn in(all 3 v specs i have are a little different), lsn-1/2 to 1 turn in from flush. Like i said all my motors are a little different, but they all seem to be very close with the hsn. That being said, check the compression on the engine after it's warm. What you're describing is a v spec that has little compression. Mine all acted like that when they need a pinch job or a complete rebuild.
Rob Hamm
The Nitro Shop
Bones Motorsports
Answer-RC/TLR/Futaba
Snow Monkey Racing
hambone is offline   Reply With Quote
Old 04-23-2009, 10:59 AM   #3
Do what Hambone said. If all checks out go to box stock settings put a new plug (P3) in and check to make sure your clutch is in good working order.
-TKO Competition Development-Sidewinder Fuel-
Alan D. is offline   Reply With Quote
Old 04-24-2009, 09:25 AM   #4
Thanks, the motor just got back from EBMODS, broke it in, idled first 2 tanks, leaned out 1/8 to 1/4 in hsn after every tank. Thanks again.
Old 04-27-2009, 09:24 AM   #5
Put in a new plug, same thing goin to put in new clutches and check for air leaks, keep advice coming, at my last draw with this motor!
Go-Tech Engines Thread MassiveMods Offroad Nitro Engine Forum 15106 06-26-2017 04:07 AM
Kyosho VoneR Thread neons Nitro On-Road 12206 06-29-2012 03:19 PM
I got a B44, Where to go? What to do? Onetrade Electric Off-Road 51 05-27-2009 12:38 PM
1/8 Offroad Buggy Mercury Racer Electric Off-Road 1510 12-05-2006 03:05 PM
