Old 04-23-2009, 08:36 AM   #1
Trader Rating: 35 (100%+)
Default diff oil help
i looked at a setup sheet on the ofna website.
it has one crt.5 setup sheet that is filled out. im looking for a good starting point, so i will use thta one, because other than that i have no idea what do set up with.
the problem i am having is, on the setup sheet it says his diff oil is 1000 front 1000 center and 500 rear.
i looked all over the web for 500 diff oil and it does not exist.
can someone shed some light on this, and give me some advice as what diff oils i should use. and let me know wich i should have on hand so if i need to make a change, ill have the right diff oils.
thanks in advance.
comedyman809 is offline   Reply With Quote
Old 04-23-2009, 09:13 AM   #2
Gliptal's Avatar
I don't know much about the CRT's but is looks like they are using shock oil in the rear diff for that setup. Some shock oils, mugen for example, are measured in CST and most (all?) diff oils are measured in CST. The rating is not comparable to shock oils measured in WT like losi and AE.
This might help
http://www.twf8.ws/php/index.php?opt...per&Itemid=175
Gliptal is offline   Reply With Quote
Old 04-23-2009, 09:35 AM   #3
that helps a lot, so what would you recommend i do, pick a brand and stick with it?
Old 04-23-2009, 09:40 AM   #4
anyone else with any thoughts??
any ideas on a good setup for the lir track in farmingdale long island ny... for my crt.5
just dying to drive this thing.
Old 04-24-2009, 04:26 AM   #5
fhgnrhg
Batam RC Kopitiam batamrc Indonesia Racing 3502 07-28-2015 12:14 AM
team magic m1b pitdog Nitro Off-Road 447 04-30-2013 08:17 AM
Mugen MTX-3 university_dave Nitro On-Road 17237 12-30-2012 12:16 PM
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 08:43 AM
Welcome to the Micro/Mini forum! futureal Micro and Mini Scales 151 01-30-2009 09:51 AM
KING OF TOURING RACE HD-F1 Georgia Racing 114 10-20-2007 08:22 AM
