16mm Big Bore Shocks RC8 >
Old 04-23-2009, 06:29 AM
ilizio(porra)'s Avatar
Default 16mm Big Bore Shocks RC8
Howzit Guys,just want some feed back of some of u that may have
the 16 mm big bore shocks on your RC8,i dont know if i should get them,
want to know if they really make a big def on the car's handling.
And what oils and spring i have to use.Thanks
ilizio(porra) is offline
Old 04-23-2009, 06:43 AM
Ive talked with team guys that swear by them. They say its the #1 improvenment with the buggy. Also, the new rc8b comes with them already so that should say enough in itself. The new buggy looks sweet.
roadracer43 is offline
Old 04-23-2009, 06:52 AM
Ok,cool.So i will get them,and the new RC8B looks good but i dont like the alu STower but everything else looks good,thanks for your info.
Old 04-23-2009, 06:54 AM
cary's Avatar
Trader Rating: 67 (100%+)
yes get them big diff
front spring ae bronze-piston 1.4x6-35wt oil-2mm intemal limiting
rear spring ae silver-piston 1.2x6-20wt oil-4mm intemal limiting
this is from the worlds setup
with stock pistons 1.3x6 front 40wt rear 30wt
cary is offline
Old 04-23-2009, 06:59 AM
Default cary
The setting u talking about is that for a smooth or bumpy track,
Old 04-23-2009, 07:04 AM
SkarTisu's Avatar
The 16mm make the car MUCH better through rough sections and on jump landings. They're DEFINITELY worth the money.
SkarTisu is offline
Old 04-23-2009, 07:08 AM
what oils and spring should a give a try on let say a bumpy track
Old 04-23-2009, 07:17 AM
SkarTisu's Avatar
Silver front spring - 35wt oil - 1.4x6 pistons
Black rear spring - 25wt oil - 1.2x6 pistons
That should work pretty well. Don't be afraid to try different settings to improve the car though.
SkarTisu is offline
Old 04-23-2009, 07:24 AM
Thanks mate!!!.
How did u know that i dont like to toy alot with settings ?
But thanks i will get the 16mm shocks and try your setting.
Old 04-23-2009, 07:48 AM
Midnight's Avatar
Trader Rating: 87 (100%+)
Originally Posted by ilizio(porra)
Thanks mate!!!.
I picked up a set a few weeks ago and put them the rear on b/c the front came with a defective shock shaft. Before I put them on the car spent alot of time on its lid, but now I can pick up the throttle way sooner, not to mention landing huge jumps. Im running like 25 in the rear with the stock pistons, I think I will try the 30 next weekend
Midnight is offline
Old 04-23-2009, 10:34 AM
El Tigre's Avatar
I think that Big Bores is the second best investment you can make in improving your handling, tires being the first (AKAs all the way). You will be so much more stable in the turns increasing cornering speed and faster in the straights on bumpy tracks especially in the rear end
El Tigre is offline
Old 05-27-2009, 11:21 AM
Default My thunder tiger eb4 wont start please help
Hi basically i have got a thunder tiger eb4 but i cant get it started some one fiddled around with the 3 needle adjustment valves and i dont know what they should be set at. Can anyone please help me. Thanks
max1989 is offline
Old 05-27-2009, 11:31 AM
Hal Hudson's Avatar
Max.
What engine do you have?
Hal Hudson is offline
Old 05-27-2009, 11:52 AM
Originally Posted by Hal Hudson
Max.
hi. its a tiger pro-21bx-r (p)/ 9436
max1989 is offline
Old 05-27-2009, 12:02 PM
JoeyTheRocket's Avatar
I thought this was "16mm Big Bore Shocks RC8" thread.
JoeyTheRocket is offline
