glow plugs and temp.
i have v-spec o s calls for a p3 plug but if i was to run
a p6 hot p7 med. p8 cold will it bring the temp. down
or is it just for timing but not messing with the hsn
just the plug will it chang the temp
the answer is both. plug temp affects timing, timing affcts engine temp. if you go too cold, you will have late ignition, uneven burn and excess heat because scavenging has been impared. ideally you want ignition advanced but not to the point to cause detonation. CR, nirto %, needle setting and plug all contribute to operating temp.
