Old 04-21-2009, 07:19 PM   #1
Default o-ring on carburator housing
where the carb attaches to the engine (the only place the whole thing can twist off) Is there supposed to be a large o-ring there?????????
dreaux is offline   Reply With Quote
Old 04-21-2009, 07:27 PM   #2
some have 1 o-ring & some have 2 o-rings. Common are one in the corner at the top & about a 1/4 the way up from the bottom of the part that slides, in a grove may be cut for an o-ring to sit in. No grove means one o-ring on the carb. Look down inside your motor & see if those channels the o-rings set in are in the block instead of the carb. Either way all our car motors have at least 1 o-ring only difference is where.
butch man is offline   Reply With Quote
Old 04-21-2009, 07:35 PM   #3
I have a groove there but there is no o-ring. I have a ofna .26 and just got it from a friend. Just wondering
Old 04-21-2009, 08:02 PM   #4
Order 1 from nitrohouse.com theyll have a exploded veiw there or can get you the part if you give them a description. That motor went though there warehouse when it came to this country from hong kong.
