Old 04-19-2009, 05:20 PM   #16
i have calmed down now. It's just i have spent so much money and time into this. Now i blow the engine and have to go to my shitty job tomorrow
dreaux is offline   Reply With Quote
Old 04-19-2009, 05:25 PM   #17
Atleast you got a job man.
I wish I had one.
-TKO Competition Development-Sidewinder Fuel-
Alan D. is offline   Reply With Quote
Old 04-19-2009, 05:26 PM   #18
did not have a guage for temp. But judging from the smoke coming from the top of the engine i would say at least 300. I mean the engine was running AT RPM'S THAT I DID NOT THINK WAS POSSIBLE.
is there any way to tell if the engine is fried??? if i take the head off would the piston be melted to the sleeve or something
Old 04-19-2009, 05:28 PM   #19
I wish I had one.
true man. Perspective. Thanx
Old 04-19-2009, 05:28 PM   #20
imaxx21's Avatar
Send a message via AIM to imaxx21
300 might shorten the life, but wont kill it instantly
richen the high end needle, and try starting it again once you figure out the linkage problem
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 04-19-2009, 05:29 PM   #21
Richen the motor up start it up get her warm shut her down and spin the flywheel with your finger. If it spins with little effort it wore out and you can rebuild it.
Try spinning it now if it spins freely then it definitely needs a rebuild.
Old 04-19-2009, 05:29 PM   #22
honestly i don't know what the temp was. The engine was smokin pretty bad. is there any way to tell if i take it apart??
Old 04-19-2009, 05:33 PM   #23
when i went to spin the flywheel it felt normal with normal compression. Is my motor ok??? seems just like before
Old 04-19-2009, 05:35 PM   #24
Electric scares the crap out of me. If your lipo decides it doesn't want to play anymore and it's 100 feet from you... by the time you get there, your entire car could be a puddle of plastic soup with chunks of aluminum.
I realize this doesn't happen very often, but it happens.
I would hold off on the Ninja until you get tuning figured out.
Team HRC Raceway - http://www.hrcraceway.ca/
Semple is offline   Reply With Quote
Old 04-19-2009, 05:35 PM   #25
Default re
if you had the air filter off and the gap on the slider was very little then there is an air leak check the head bolts make sure the carby is tight and tha back plate is tight how old is the motor?was it new or used ? the only way a motor can run wild is if there is an air leak or the throttle is wide open or near it
toofless is offline   Reply With Quote
Old 04-19-2009, 05:35 PM   #26
You might be alright then man.
Once you get it running spin it again and it has compression then your golden
Old 04-19-2009, 05:37 PM   #27
Air leak could come from the fuel tank/lines as well. Bubbles in the fuel line will lean your engine out pretty fiercely.
Old 04-19-2009, 05:38 PM   #28
Or it was really really lean.
Old 04-19-2009, 05:44 PM   #29
pattillo123's Avatar
Location: cullman al.. {1/2 mile from cullman RC hobbies}
Sounds like you are very lean on the High speed needle and possibly the low speed needle as well! The carb has 3 adjustments on it, LSN(low speed needle)HSN(high speed needle) and idle adjustment. Look at the picture below.... Turn your high speed needle out about 1.5-2 turns and see if that makes it any better. Also turn the LSN out about a turn and see if that helps.
Good luck to you!
~~~CANT PISS ON IT IF YOU CANT CATCH IT~~~
pattillo123 is offline   Reply With Quote
Old 04-19-2009, 05:45 PM   #30
Good luck to you!
I wish I had photoshop
Sydney Model Autosports Inc [smaracing.org] The Ideas Man Australian Racing 25418 08-22-2017 01:27 AM
$$$ Person to make the 50K post wins $25.00 $$$ racer1812 Chat Lounge 51794 08-15-2017 08:21 AM
Adelaide Nitro Offroad Racing Club oblivion Australian Racing 19736 01-14-2017 01:12 AM
Nitro On-Road Addict sa RC Manila Racers 12522 12-27-2015 05:51 PM
Hobao GPX4 Pro chrisman Nitro On-Road 781 05-06-2013 07:47 PM
Jammin X1 - so close yet so far beetlebz Nitro Off-Road 4524 03-25-2012 01:54 PM
Metro-Pittsburgh Carpet Racing @ Steel City Hobbies McSmooth Racing Forum 86 04-29-2007 09:24 PM
