Old 04-19-2009, 02:01 PM   #1
Default nitro fuel
hi i have changed from 16% to 25% nitro fuel and now a can not got it started (thunder tiger eb4 pro 21)can any one tell me what im doing wrong thanks bryn
bryn1 is offline   Reply With Quote
Old 04-19-2009, 02:20 PM   #2
Gliptal's Avatar
You will have to re-tune the engine for 25%, richer I believe (CCW). It shouldn't be that far off though, is it not firing at all?
Also, what type of fuel was/is it? some of the sports blends have a ton of oil in them, in that case it may need to be leaner.
Gliptal is offline   Reply With Quote
Old 04-19-2009, 02:24 PM   #3
i have tried changing the settings but still no luck do you the best needle settings will i need a different glow plug and whats ccw .
Old 04-19-2009, 02:31 PM   #4
the 16% was tornado and the 25% was some green colour stuff it seem cheaper than the other stuff ithink it is crap stuff
Old 04-19-2009, 02:34 PM   #5
Gliptal's Avatar
CCW - counter clock wise
For the needle settings I don't know, the manual may have the default needle settings.
Make sure you glow plug is working, take it out and see if it glows. You normally want to run a cooler plug with higher nitro but it should run regardless.
Old 04-19-2009, 02:40 PM   #6
glow plugs work fine i read somewere about putting more shims on the head do ineed to do this ,maybe i will get some 16% tomorrow and try again could the engine be broken
Old 04-19-2009, 02:56 PM   #7
Also, check your fuel pressure line, and fuel line. If your changing to more nitro content, you should actually lean it out a bit. Put a new glowplug in before the re-tune.
Oh,... and check the motors head screws for tightness...
CarCrazy is offline   Reply With Quote
Old 04-19-2009, 03:16 PM   #8
jrwoodchuck's Avatar
???? higher nitro means richer settings, not leaner.
Doug
TLR 22/M-11
“Looks like I picked the wrong week to quit sniffing glue.”
jrwoodchuck is offline   Reply With Quote
Old 04-19-2009, 04:26 PM   #9
I also have to lean it when I drop down to 20% & richen it back up when I use 30% again.I figured it was from 10% less boom juice(nitro) & 10% more cooling juice(alchohol) but,everyone tunes different for a different feel & alt & weather is different & so are motors/plugs.16-25% will not stop it from starting if your tune was good before & most race level motors are shimmed for 25-30% nitro from the factory so you shouldnt need to change that.look for something else.Can you see fuel through the lines getting to the carb? Did you do anything else like seal the carb when you changed over?Lastly just because a glow plug glows dont mean its good.Its the platnum plating on the plug wire that when is hot ignites the fuel NOT just any old hot wire so if the platinum is worn down it will still glow but be no good.Think of the little things nitro % alone wont keep it from running.
butch man is offline   Reply With Quote
Old 04-20-2009, 08:17 AM   #10
hi just tried to start it again i noticed fuel coming out from near the flywheel when i pull the cord could this be the problem ifso is it repairable or not .
Old 04-20-2009, 08:35 AM   #11
halfman's Avatar
I think that if you have fuel coming out of your crankshaft near the flywheel then your engine bearings might be going out
also i run 20% sidewinder fuel. it get good gas mileage and has less wear on your moter. Also what engine are you running
halfman is offline   Reply With Quote
Old 04-20-2009, 08:50 AM   #12
thunder tiger eb4 pro 21 i have changed fuel and can not start i also tried it in another car and still no go any ideas the fuel is nitro monster juice 25%
Old 04-20-2009, 02:09 PM   #13
Yep, thats what I thought. Last week I had to lean the bottom and top two hours each, when switching from 20% to 30%. The 30% actually cooled better, and richened my motor up a ton. Very strange...
Old 04-25-2009, 11:45 AM   #14
i have finaly got engine started today but im getting alot off oil in exhaust what should i do
Old 04-25-2009, 01:36 PM   #15
Gliptal's Avatar
Too rich.
Its common for there to be a little bit of oil coming out of the exhaust, especially with high oil sport fuel, but if its "spray painting" the ground, too rich.
Learning to tune an engine can be tricky, it is really best to have someone with some experience help you out if possible.
Here is a link with some useful info, check out the Paris racing tips. Some of the info is out of date, the tuning advice is good though.
ARIZONA TOURING CAR RACERS
Nitro On-Road Addict sa RC Manila Racers 12522 12-27-2015 05:51 PM
RC news at Kuching evoton Malaysian R/C Racers 827 11-05-2013 09:37 AM
Food for Thought - Cheaper to run Thopper Electric Off-Road 38 12-22-2008 07:52 PM
GS CUP Malaysia 2008 jets Malaysian R/C Racers 328 07-08-2008 08:40 AM
GOOD FUEL scarlet Nitro On-Road 147 03-10-2007 08:41 AM
Losi LST or Traxxas Revo INVIZAGOD Monster Trucks 216 06-09-2005 07:03 AM
Wanted- Hpi Nitro Any Kind Post Here! dizboihuy R/C Items: Wanted to Buy 6 03-21-2003 05:30 AM
