Old 04-19-2009, 12:26 PM   #1
Default car is idoling at full speed
set my end point adjustment like the instructions said (but i think the carb was all the way open when i did it). i opened the idol screw about 1mm (which was a couple turns around). Closed the main needle all the way and opened it one and one eighth turn. When i crank it up it idols at full speed! Help please. What am i doing wrong???
i can't see how it would matter about my end point adjustment, since the needle is what controls the gas flow.
dreaux is offline   Reply With Quote
Old 04-19-2009, 12:36 PM   #2
bluer322's Avatar
with eng. off turn on your radio then the receiver, pull the filter so you can see in the carb and see how far the carb is open. if the servo horn is set right loosen the round pull nut and push the carb linkage so that carb only opens to 1mm at idle.
T. Nicholson
Murnan Modified Motors
Matrix Tires
Serpent, 748tq
bluer322 is offline   Reply With Quote
Old 04-19-2009, 12:38 PM   #3
imaxx21's Avatar
Send a message via AIM to imaxx21
the main needle at one and one eighth turn??
where did you read this?
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 04-19-2009, 12:50 PM   #4
yes main needle at one and one eigth turn. How much should i screw the idol needle out??? and i guess what the other guy was saying was set the carb at idol ant the servo on neutral and put the horn back on???
Old 04-19-2009, 01:02 PM   #5
bluer322's Avatar
what I'm saying is to check to see if the carb is being pulled open when the radio/receiver is on
T. Nicholson
Matrix Tires
Serpent, 748tq
Old 04-19-2009, 04:16 PM   #6
cweb's Avatar
Trader Rating: 35 (100%+)
+1, you need to set the throtle linkage with the electronics on . once you get that squared away you can start on the needle settings.
Team Whiteknuckle- CW
B5M- viper-rc/Hitec/avid/schelle/mip/protek-rc/lunsford
T5m- viper-rc/Hitec/avid/schelle/protek-rc/lunsford
cweb is offline   Reply With Quote
Old 04-19-2009, 04:18 PM   #7
DANE_TRAIN's Avatar
Trader Rating: 20 (100%+)
What engine/car/radio ?
Pro4mance Hobbies
DANE_TRAIN is offline   Reply With Quote
Old 04-19-2009, 04:39 PM   #8
mbx6, m11 radio and ofna .26 engine (getting a ninja in a couple weeks) linkage is fine i am looking at it. with the servo in neutral the brakes are in perfect position and the carb is only open very very slighty less then a eight of a inch. Still it is running at FULL SPEED!!!! damn engine was smoking last time i tryied to tune it down
something is seriously wrong.
Old 04-19-2009, 04:42 PM   #9
If you were 1/8th of a turn out from closed on the high speed (main) needle then your motor is done.
I had an Ofna motor and did the same thing.
-TKO Competition Development-Sidewinder Fuel-
Alan D. is offline   Reply With Quote
Old 04-19-2009, 04:46 PM   #10
i don't understand. that is the air intake right?? I don't know what you mean by one eight a turn?? i had the carb open (with the throtle closed) about less then a one eigth gap. So i burned it up???? man screw this. I am selling and getting electric
Old 04-19-2009, 04:55 PM   #11
imaxx21's Avatar
main needle = high speed needle
-Crash
Old 04-20-2009, 10:56 AM   #12
cweb's Avatar
HOLD UP, before you sell and go electric. you can't adjust the amount of air the engine takes in with the carb needles. you adjust the fuel ratio with the needles. if the engine got realy hot you were to lean( not enough fuel). Try this before you call it quits. turn the main needle( the big one that sticks up) all the way in gently, then back it out 2-1/2 turns. see how the engine reacts when you do this. And if your engine still has good pinch, Its not smoked. pm me if you haven't given up and make + progress.
