Old 04-19-2009, 09:17 AM   #1
Default Losi 8ight Fuel Line Loose on Carb
Hello all,
I had to remove the engine in my Losi 8ight. I went to attach the fuel line to the carb and it won't stay on. I'm guessing the lubrication in the nitro fuel is making it too slippery. Anyone have this problem? Do I need to clean off any nitro residue from the hose and fitting before re-attaching the hose? If so, what is recommended as a cleaning solution? Do they make a small cable clamp (or similar home-made item) to keep the hose firmly attached?
Thanks.
FL_Offroad is offline   Reply With Quote
Old 04-19-2009, 09:26 AM   #2
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Originally Posted by FL_Offroad View Post
Hello all,
Thanks.
Clening may help. You can take the line off and clean it out with nitro spray. You can also cut a 1-2mm long piece of fuel line off, and use a pair of pliers to streach the piece over your line at the very end. This will help to keep the line on. And the other option is to use a small zip tie wrapped around the line to hold it firmly in place.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 04-19-2009, 09:42 AM   #3
Frank L's Avatar
Trader Rating: 148 (100%+)
Use fuel tubing the zip tie has sharp edges and can cut into the line from all the vibration. I have this same problem with the stock losi fuel line. I replaced it and the problem is gone. Personally I like the Kyosho brand but any brand will do. The losi line just seems to get softer and enlarge a little easier than other brands.
Old 04-19-2009, 11:19 AM   #4
scwrod's Avatar
Just cut a little off of the existing line where it goes into carb or get some new fuel line
hbracing.com tritonrc.com raceaka.com
scwrod is offline   Reply With Quote
Old 04-19-2009, 12:14 PM   #5
madmaxx's Avatar
i use the piece of fuel line trick, you can also find metal clip's in the airplane section of your LHS
YOU CAN'T HANDLE THE TRUTH!
>> http://ca.geocities.com/jleblao/ <<
^^MC carbon custom carbon fibre REVO part's!^^
madmaxx is offline   Reply With Quote
