Old 04-18-2009, 06:06 PM   #1
Default Tuning help appreciated
I already posted this in the Monster Truck forum, but they said to come here.
Anyone have any tips to get the bog out of the bottom end of my engine?
It's an LRP Z.28R Spec 3 in an Associated MGT. I have the high end figured out and it flies but it bogs pretty badly when coming off of idle. I tried leaning it out ~1/8-1/4 of a turn on the low/mid needle and it started not being able to hold an idle, went the other direction and the bogging just got even worse.
I am running 20% Traxxas Top Fuel with the stock gearing, and as I said earlier, once it is moving it just flies, but down low it is just annoying.
I have about a gallon on the engine, it still has an insane amount of pinch, and when I take the temp it hovers around the 210 degree range.
Any help is appreciated."
howtowakeakar is offline   Reply With Quote
Old 04-18-2009, 06:10 PM   #2
When you leaned the low speed needle did your idle get higher? If it did lean the low speed needle end out by 1/8 of a turn at a time and also lower your idle by twisting the idls stop screw counter clockwise.
rgrassey@me.com is offline   Reply With Quote
Old 04-18-2009, 06:23 PM   #3
It didn't get noticeably higher, just choppier until it bogged out. I'll try leaning it out though, see if that helps.
Old 04-18-2009, 07:45 PM   #4
Your fuel is the problem.....IMO the best are Nitrotane, Byron, and Sidewinder.
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Old 04-18-2009, 07:49 PM   #5
It actually could be the fuel, not because it it Traxxas (but once it gets closer to summer I'll switch to Byron's), but because this gallon is about 5 months old, and it was stored in a fairly cold area.
I'll crack open the fresh gallon tomorrow and see if that makes a difference.
Old 04-18-2009, 08:23 PM   #6
also i think top-fuel has a very high oil content but idk what that would do. I really just thnk its a tuning issue.
Old 04-18-2009, 08:41 PM   #7
I also think it is a tuning issue, I'll lean out the idle tomorrow, but in very small increments, see if that helps.
Old 04-18-2009, 08:44 PM   #8
VenturaDC's Avatar
Trader Rating: 32 (100%+)
if tuning doesnt help switch to a stiffer clutch spring and make sure the clutch bell bearings are in good working order.
Dustin Colt45 Aguirre
Kyosho RB6--Futaba--HW--Shuurspeed 17.5
Kyosho SCR--Hitec--Lrp--Yeah 13.5
Durango Dex210--Futaba--Trakpower--Tacon 8.5
VenturaDC is offline   Reply With Quote
Old 04-18-2009, 09:13 PM   #9
MadRussian's Avatar
Get some Byrons Gen 2 25-30%, lean the bottom, add 2 thicker clutch springs and keep one stock, run Dyn max lifes.
I raced a full cf shassis LST2 with a LRP Spec 3, still have it actually, thinking about selling it as I run Z-Car buggy and soon to be truggy now
MadRussian is offline   Reply With Quote
Old 04-18-2009, 09:18 PM   #10
Looks like I'll be heading to the LHS next weekend, or might just order everything from Tower tomorrow, can't even run it right now, stupid screw came out from the steering while running it.
Old 04-19-2009, 03:02 PM   #11
Also, what size glow plug does the LRP take?
I searched around and couldn't find a definite answer.
Old 04-19-2009, 03:11 PM   #12
Trey7's Avatar
you can run mc 8,9, or 59. I always ran mc 59 in my LRP .28
Trey7 is offline   Reply With Quote
GRP... Engine... Thread... xlgraphicspro Offroad Nitro Engine Forum 2135 09-10-2013 08:46 AM
Kyosho Off-road forum Taz_S Electric Off-Road 87 03-30-2010 11:55 AM
rb c6 lsn tuning help needed chris52 Electric Off-Road 7 03-29-2007 06:34 AM
***Rose Cup Weekend***Free Open Track*** rosecity Northwest Racers 164 06-10-2006 09:53 PM
New and need help on what to buy JD2006 Rookie Zone 7 01-27-2006 06:19 PM
Complete Noobie Sheazy0219 Rookie Zone 9 06-26-2004 12:03 PM
tuning issue bt Nitro On-Road 15 05-06-2003 02:40 AM
