Old 04-17-2009, 09:57 PM   #1
MoparRules's Avatar
Send a message via AIM to MoparRules Send a message via Yahoo to MoparRules
Default exhaust temp. Q.
hi! im trying to run a custom exhaust setup on my truck except im dealing with some sharp angles to work by with angle tube. i was just wondering if the exhaust gets hot enough to melt semi-thick rubber tubing. also is it hot enough to melt a rubber air filter tube? i need one 90 degree angle.
thanks in advance.
outa the hobby
MoparRules is offline   Reply With Quote
Old 04-17-2009, 11:45 PM   #2
imaxx21's Avatar
Send a message via AIM to imaxx21
a lot of RTR cars use silicone exhaust couplers...
GS Silicones makes a bunch in all sorts of sizes and colors
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 04-18-2009, 07:16 AM   #3
MoparRules's Avatar
link? i found GE silicones from google but im not sure if its the same..
outa the hobby
Old 04-18-2009, 08:50 AM   #4
markr04's Avatar
He meant to say GS Racing. The GS stands for General Silicones, not the same as GE Silicones.
Xray 808 2010 Spec - O.S. V-Spec Speed - Airtronics M11-DSSS
Losi 8ight-T 2.0 - RB Killer 9 - Airtronics M11-FHSS-2
Losi XXX-CR - Tekin RS / Novak Ballistic 13.5 - Airtronics M11-FHSS-2
markr04 is offline   Reply With Quote
Old 04-18-2009, 08:56 AM   #5
MoparRules's Avatar
well the america section dosent work.
outa the hobby
Old 04-18-2009, 05:06 PM   #6
Rocket XUT's Avatar
GS Racing has pretty much abanded the US but A Main still stocks all there parts try this
http://www.amainhobbies.com/index.ph...acturers_id=97
I may be dyslexic but it makes perfect sense to me.
Rocket XUT is offline   Reply With Quote
Old 04-18-2009, 05:13 PM   #7
MoparRules's Avatar
do you guys think air filter elbows will hold up to exhaust temp?
outa the hobby
Old 04-18-2009, 05:32 PM   #8
SPEED37's Avatar
Take a look at this stuff.........Not a 90 but looks like it could be bent.
http://www.davesmotors.com/s.nl/c.88...t.A/id.4391/.f
JAMMIN X2 CRT/HOUSTON/NOVAROSSI P5XS/OFNA-053
JAMMIN X2 CR/NOVAROSSI
SPEKTRUM/DX3S
BCG INDUSTRIES= Absolutely the best paint on the planet.
TEAM TERRIBLES
SPEED37 is offline   Reply With Quote
Old 04-18-2009, 05:33 PM   #9
imaxx21's Avatar
right, thanks guys
air filters are pretty soft
-Crash
Old 04-18-2009, 05:35 PM   #10
MoparRules's Avatar
right, thanks guys
the elbows arent, well at least not HPI's
and i think ill try that tubing. thanks guys.
outa the hobby
Old 04-18-2009, 07:12 PM   #11
chunk t's Avatar
Mopar,
the Silicone couplers are joiners to allow flexing of the exhaust when A rigid 1-piece cannot be used; and/or to allow minor changes to the exhaust's overall length. It is not intended for bending.
The exhaust system for your engine is designed to carry a pressure wave away from and back to the exhaust port. Changes to the inside-diameter (by bending) or any type of deformation will have a direct and dramatic effect on the exhaust's efficiency. You can come up with your own exhaust to fit your needs but you need to have some performance criteria laid out before you piece things together. You can really quickly spend a lot of money just to have cobbled together muffler.
Tell me what you got (engine & Pipe) & what you are trying to do and maybe I can give you a few generalities that may help you out
chuck "chunk" thomas
1:10, 2-wd Stadium Trucks
B-Mod Tunnels
If ignorance is bliss... I must be in heaven!
chunk t is offline   Reply With Quote
Old 04-18-2009, 07:40 PM   #12
MoparRules's Avatar
Originally Posted by chunk t View Post
Mopar,
can i just PM you? i hate taking up space in public for personal conv.
outa the hobby
Old 04-19-2009, 10:14 AM   #13
chunk t's Avatar
yep. go for it.
B-Mod Tunnels
Old 04-19-2009, 04:38 PM   #14
MoparRules's Avatar
yep. go for it.
YGPM
outa the hobby
Old 04-19-2009, 06:57 PM   #15
chunk t's Avatar
YGPM
reply sent.
B-Mod Tunnels
Newbie questions WillB Rookie Zone 15 02-08-2005 08:21 AM
