can the fuel line and tank contact the muffler???
What i mean is, my fuel line runs along side my mufler. Does it matter if it hits it??? Is the fuel tubing made out of high temp rubber hose??? What about the fuel tank??
I would also try and stay away from the pipe. Although the fuel line is usually strong enough to withstand the heat, it's the fuel getting warmed up before it gets to the carb is what I'd be concerned about a little more. Some fuel tanks actually have places where you can mount clips to route your fuel tubing through. If the fuel line hits it when you bounce and stuff, it should be fine.
Shouldn't hurt as long as its not laying on it constantly even if it is it will just make it become brittle faster.
The tank on the other hand may not be so good dont know if it will melt depends on the material but heating up the fuel is probably not good.
I believe they make heat shielding for fuel lines if i remember correctly my 2.5 tmax came with it on the line that ran over the exhaust try looking around on Amain or tower
Yup, Muffler/exhaust+fuel tank=melted tank wall. I've had this happen before to me on my LSP when the pipe holder backed out. Fortunately, the tank held up and I was able to finish the race.
