Old 04-16-2009, 10:36 AM   #16
SkarTisu's Avatar
Send a message via AIM to SkarTisu Send a message via Yahoo to SkarTisu
Originally Posted by Ralph Walters View Post
Run m3 holeshots on the front and rear. Problem solved.
Or JConcepts Double Dee's front and rear in green compound. The GT2s respond very well to small pin tires front and rear on almost every kind of dirt.
Marshall Skare
Team Associated - Reedy Powered - JConcepts - LiveRC.com
SkarTisu is offline   Reply With Quote
Old 04-16-2009, 11:46 AM   #17
+1 or+2 or +3 or whatever number we're on with the DD's or Holeshots F&R. Great on a hard packed track. Try the 30 deg caster blocks on the front, should give you a little more turn in steering and tame down the mid to exit. From what you've described with your engine, it sounds like it's fat on bottom. The Smoothy is a great pipe and you shouldn't lack any bottom end power with it. If you want tons of bottom end, go back to the stock AE pipe. Also, you might try the NTC3 1.0 clutch springs, it will hit harder on the bottom.
BTW, the slipper is not a traction control device, your finger is. The slipper is there to save your drive train. Set it like it says in the manual and leave it alone. I'm wondering if it isn't slipping too much and then catching mid-corner. Might also explain the lack of bottom end.
cjtamu is offline   Reply With Quote
Old 04-16-2009, 11:52 AM   #18
tc5 man's Avatar
the small pins do work good on the gt2 but with the shocks in rear standing up it seems to jump better then having it laydown,the rib tires with a soft compound does cause understeer if u ask me
Old 04-16-2009, 12:06 PM   #19
jabroni racing's Avatar
Trader Rating: 36 (100%+)
Send a message via Yahoo to jabroni racing
Tires is the biggest differrence you feel rite away, I have ran rib fronts, and hole shot fronts.. Ive had shock blown out and no oil and the truck still get around ok.. the King pins seem to be lousey when i tried them in the corner, the always washed out on me,,.
www.facebook.com/jay3638
jabroni racing is offline   Reply With Quote
Old 04-16-2009, 09:18 PM   #20
Thaks for the help guys. Sounds like its bout time to order tires. First race of the year is this Saturday guess we will have to try the ribs for now. Thanks again
RadioCircus is offline   Reply With Quote
Old 04-16-2009, 09:58 PM   #21
tc5 man's Avatar
the small pin tires do ware quickly if u break hard espially in soft compound
i recomond imfar pins if u want them to last i would get meduim soft.
they work good win the track has moist on the dirt but when i real wet they suck .
Old 04-16-2009, 10:15 PM   #22
SkarTisu's Avatar
I'm going to experiment more as our summer series goes on this year, but I was starting to really like the truck last year as I started going to softer springs and lighter oil. I'm currently running silver fronts with 30wt and green rears with 25wt.
Marshall Skare
Old 04-16-2009, 10:35 PM   #23
tc5 man's Avatar
inst 25 w in the rear to soft and bottom out easy with the green springs,i try out the silver springs in the front ,i run 35 f gold and 35 r green but it seems to jump better with the same weight all a round
OS FS26S-C 4-stroke development mxwrench Offroad Nitro Engine Forum 1643 Yesterday 05:38 PM
Veteran TAMIYA TA03 fans! porkybmx Electric On-Road 1496 08-12-2016 06:02 PM
SC10 Thread JDCrow Electric Off-Road 12123 05-29-2012 04:40 PM
360 RC SPEEDWAY & HOBBIES Sal Amato Racing Forum 6760 06-20-2010 07:10 AM
Project Team Kassanova K2 buggy eds24 Electric Off-Road 89 05-06-2009 09:57 PM
2007 WINTER NATIONAL! SuperDaveNT Canadian R/C Scene 1078 05-25-2007 06:44 AM
