Tony's Screws Starter Box Lift Kit
Tony's Screws Starter Box Lift Kits
The stock rubber feet on the Mugen BII off-road starter box are only 5/16" (8mm) tall. When you put a truggy on the box with the larger 1/8th truck tires and blip the throttle, the tires hit the surface of the table. These new feet are 13/16" (21mm) tall raising the box 1/2" (13mm).
Kit includes (4) rubber feet, (4) 5x20mm button head screws and (4) 5mm locknuts. Simply mark your box, drill a 5mm hole (approx 13/64") and mount. They should fit most other starter boxes as well.
Best regards,
Best regards,
do u have them for losi eight boxs
Best regards,
Tony, you need to include washers for the screws. I tightened mine down too much and the screw just passed all the way through the rubber and stripped out the hole. It was an easy fix, but its hard to tell when its tight, because the rubber offers no resistance. Washers are needed for future shipments
