Old 04-10-2009, 08:04 AM   #1
revo61's Avatar
Trader Rating: 18 (95%+)
Default Vspec problem
I got the Ofna bearing puller to replace my bearings. Well I got both out, but when I tried to put the new ceramic rear bearing in I put it in backwards. So I was trying to get it out no luck. It is less than a mm from the exit and very stuck. I broke the tool trying to get it out. So can I run it with the bearing backwards? I have put it in the oven and it still won't come out. Any ideas?
JQ The Car Black Edition/Reds R7E/Reds 2113 pipe
Airtronics MT44/Savox servos
Sidewinder Team Strike V2 30%
USA.JQRACING.COM / WWW.NEMORACINGUSA.COM
revo61 is offline   Reply With Quote
Old 04-10-2009, 09:22 AM   #2
rc pete's Avatar
Crank up the oven. I don't like going over 300, unless the bearing is really stuck... up to 325 should be ok. And leave it in there for a while (like 20 min).
The aluminum case WILL expand more than the steel bearing.
Just be ready with your oven mitt and the crank when you pull it out of the oven, or anything else that fits. Put it in the bearing and wiggle it out while it's still hot.
PS: I'm assuming that you're taking everything else off the case when swapping bearings... no need to expose any seals to that kind of heat.
Team Associated - Reedy - Pro-Line - RC Depot - OS Engines - 110% Racing - LD Graphics
rc pete is offline   Reply With Quote
vspec unbeatable?!?! liteumup387 Nitro Off-Road 36 06-14-2009 06:13 AM
Vspec Tuning Problem Krawl Nitro Off-Road 42 05-01-2009 12:54 PM
.21 ENGINE PROBLEM?!?! wstuart Nitro Off-Road 6 12-26-2008 02:37 PM
OS VZB S-Spec Problem AERC8 Nitro Off-Road 13 11-06-2008 11:11 AM
vspec carb problem spudly12 Nitro Off-Road 19 07-10-2008 02:27 PM
vspec problem emjdrvr Nitro Off-Road 33 05-31-2008 12:54 AM
RB S5 or the OS VG .21 jrwoodchuck Nitro Off-Road 11 03-09-2008 05:40 PM
