Old 04-09-2009, 11:29 PM   #1
Default Can I change the fuel percentage?
ok so i was went to break in my LST2 and i ran 20 percent on the first tank i didnt even notice that i was using 20 percent can i change it to 30 percent because i only ran one tank on 20 percent
Hpi vorza
e-revo bl
slash 4x4
salabarria is offline   Reply With Quote
Old 04-09-2009, 11:33 PM   #2
imaxx21's Avatar
Send a message via AIM to imaxx21
sure
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 04-09-2009, 11:37 PM   #3
You will be perfectly fine
Ive done everything Hank did but die
NCWC is offline   Reply With Quote
Old 04-09-2009, 11:50 PM   #4
ok thanks guys just wanted to make sure i didnt want to mess up the engine or anything
Hpi vorza
e-revo bl
slash 4x4
Old 04-10-2009, 12:29 AM   #5
When you change nitro percentages, you will need to adjust your needle settings and also start your break in process all over from the start.
HB D8T with BCE Chassis, ACE Shock towers and motor mounts, M2C Rear Suspension system, KH front steering plate and chassis braces, Lunsford Ti-turnbuckles & hinge pins, OS Speed motor, Hitec 5995TG steering, Futaba 9351 throttle/brake, OS 2060 pipe, and J concepts Punisher Body.
HB D8: CEO Mods Novarossi P5K with JP4 tuned pipe, JR 9000T steering, JR 8800T throttle.
gotspeed_2000 is offline   Reply With Quote
Old 04-10-2009, 02:31 PM   #6
sharkman's Avatar
Trader Rating: 17 (100%+)
You do not need to break your engine in all over again.
Adjust your needles and go from there.
cumberland rc racers
8ight B 2.0 brushless
tekin rx8 1550kv
sharkman is offline   Reply With Quote
Old 04-10-2009, 02:38 PM   #7
imaxx21's Avatar
-Crash
Old 04-10-2009, 02:40 PM   #8
guambomb's Avatar
guambomb is offline   Reply With Quote
Old 04-10-2009, 04:00 PM   #9
beginner4life's Avatar
Trader Rating: 9 (91%+)
Generally engines don't mind going up percentage, but i think going down is not good.
*Team Terribles*
RC8T-RB S3-Hitec Servos- Spektrum
beginner4life is offline   Reply With Quote
Old 04-10-2009, 09:28 PM   #10
deweyharding's Avatar
Trader Rating: 39 (100%+)
Do you generally have to richen the needles going up in %
deweyharding is offline   Reply With Quote
Old 04-10-2009, 09:34 PM   #11
Integra's Avatar
it all depends on the fuel.
Old 04-10-2009, 10:55 PM   #12
but what happens if going down? is it a bad thing or i just have to re adjust needles?
mc_chofo is offline   Reply With Quote
Old 04-11-2009, 08:24 AM   #13
sharkman's Avatar
Just readjust the needles. you are just resetting the needles to adjust for the different ignition timing of the different %'s.
It is just a matter of personal preference but I always found with big blocks that going to a higher % needed a colder plug. 20% I liked a medium plug.
I have had 4 of these engines with the lst2/8ight/muggy.
tekin rx8 1550kv
Off Road Thread (ALL SCALES UNITE) suntok2 Manila Racers 18645 01-07-2016 01:13 AM
Air filter rockfordccinc Nitro Off-Road 32 09-13-2009 08:32 AM
Shimming, nitro %, glow plug and timing blanks596 Onroad Nitro Engine Zone 30 06-15-2007 02:51 AM
GOOD FUEL scarlet Nitro On-Road 147 03-10-2007 08:41 AM
2007-2008 ROAR Presidency - Carl Giordano Carl Giordano Racing Forum 324 11-16-2006 06:40 AM
nitro fuel qyestion! n3rd420 Electric Off-Road 16 04-20-2006 01:45 PM
