8 2.0 rear bearing
No problems here either. Maybe if the car was run for 2 gallons of fuel or more with ZERO maintnenance, then there might be a problem. Just check them when your going thruogh the car for your regular maintnenace.
well the only thing i had a prob with was the back left out drive was torn up and the dog bone pin was still like new after its first gallon. i checked the shim spacing and it was 2mm on the left and 4mm on the right. so now its
3mm on each side and i hope this fixes this problem.
call losi they will replace the outdrive.....there have been a couple instances where this has happened...its not a shimming issue...its all about the Diff outdrive.
well i put my 1.0 rtr out drives on it cuz they have lasted over 9 gallons and are still in good shape.
