Old 04-09-2009, 08:50 AM   #1
mista.matrix's Avatar
Default shim issues in my X2 diffs
one or two shims in my diffs, useing steel gears....?
mista.matrix is offline   Reply With Quote
Old 04-09-2009, 09:19 AM   #2
Trader Rating: 36 (100%+)
If you're asking about the shims that gon outside of the diffs, this is a direct quote from Chad Bradley.
"when the car is brand new I shim the gear mesh of the diff and pinion
1 on the diff gear side and 3 on the diff case side, after a couple
club races i shim 2 and 2."
If you're asking about the smaller, internal shims... direct quote from Rick McCreary...
"i use 2 behind each gear on all my X2 stuff. i run my internals way
longer that 4-5 races. i should probably change them but i haven't. i
have never changed the ones in my truck from the day i got it (right
after 2007 truck nationals) still going strong. changed the oild but
not the gears. "
Hope this helps.
NitroOB4You is offline   Reply With Quote
Old 04-09-2009, 09:23 AM   #3
sorry, it was the internals I was speaking about.....
it for my trruggy
Old 04-09-2009, 09:39 AM   #4
joeling's Avatar
If u are using the hardened one from HB or Sacker, Use the black shims that come with the gears. I am doing that for most of my HNs without any problem so far.
My LHS also mentioned to me that the savage ones fit too but I have never tried & also not sure if they are hardened.
Regards,
Joe Ling
HN X2 CR OS Speed WC Ti, HN X1 CR Polyquest 5S Neu 1512 2000kv MMM
HN X2 Neu 1515 2000KV Polyquest 5S 6000mah MMM, HN X2 OS Speed WC
Hyper 9e Medusa 2000KV 4S 6000mah MMM, Hyper mini STe Medusa 3300KV 3S 2500mah MM
Savage FLM ext. 5S MMM 8XL, E REVO Medusa 1600KV 6S MMM
Thunder Tiger ST Neu 1515 2000KV Lutach esc 5S 4800mah
joeling is offline   Reply With Quote
Old 04-11-2009, 08:52 PM   #5
TTT
