Losi clutch question
I tried to search for this but could not find the answer. Is there a 3 shoe clutch I can put on my Losi and what do I need to do it, Thanks
Ive run both in my losi, the mugen clutch and my losi clutch, i like the losi better, I always run the dynamite maxlife shoes,on all my clutches, they are a great blend of grab and longevity, to use the mugen clutch, buy the losi adjustable motor mount, and it allows you to use the losi clutch, or the mounts flip around and you can use a mugen stlye clutch
The Losi clutch is the best, easiest and most adjustable clutch out there. No reason to run any other clutch.
Agree with all thing said in the above reply. Stay with the Losi.
I've only had the losi clutch for about 2 weeks, silly easy to work on, but it seems to mushroom shoes pretty quick. Mine is the stocker in a losi 8t 2.0. wanna get some longer lasting shoes, any suggestions?
Thanks for the replies, what springs do you use?
Never use silver springs....all they do is burn up shoes....gold/green or gold/black is a common set-up to run.
+1. The silver springs seem to be too much. I used to burn up the Max-life shoes in one day and the Losi or Kingheadz in 2-3 weekends. Once I dropped the clutch springs to 4-green or 2-green/2-gold the shoes will last a long, long, long time.
The only shoes I've tried are as mentioned above. All three of them come with a beveled edge around the contact point to delay the typical mushrooming from aluminum shoes. But my clutch now goes 2-3 gallons before needing deburring.
Always clean and relube the bearings as much as you can. I take my engine off after each raceday or race weekend to inspect, clean, maintain.
X2 on every point made.
I never had a problem with my losi clutch....it was the bell bearings allway going out i had a problem with......
I now run M2C 4shoe clutch with onfa clutch bell... an have great luck with it.... an a kinghead motor mount.....
http://www.m2cracing.com/category.sc...?categoryId=25
i run .9's with anything from Reg hard to light med on my JPX.21...BEST set-up i have EVER ran.
