Old 04-09-2009, 09:48 PM   #16
Just a quick question. Will harder springs make your car more snappy on the bottom? What are the flaws of runnning a harder spring.
rgrassey@me.com is offline   Reply With Quote
Old 04-09-2009, 09:59 PM   #17
HulkNT1's Avatar
If I want to run the Losi Clutch setup on my Xb808 what parts would I need? I went to Amain and they do not sell the complete setup on in parts and then I went to Team losi website and did not find them..
HulkNT1 is offline   Reply With Quote
Old 04-10-2009, 01:03 AM   #18
MaTt 93's Avatar
Send a message via MSN to MaTt 93
You can get a full losi clutch setup of ebay, and for parts you would need im guessing you will need the losi engine mounts.
TLR 22 - Spektrum - 7.5 Speed Passion V3 - LRP
Durango DEX410R - Spektum - 5.5 Speed Passion V3 - LRP
SECOND PLACE IS THE FIRST LOOSER !!
MaTt 93 is offline   Reply With Quote
Old 04-10-2009, 07:13 AM   #19
Integra's Avatar
Silver Gold Green Black.....DO NOT use silver tho...they WILL eat the shoes for breakfast.....flaws of running a stiffer spring are excessive heat excessive slip and a shoe that just wont last as long.
you would need all this
http://www.carolinasrc.com/Webstore/...idproduct=2673 Flywheel nut
http://www.carolinasrc.com/Webstore/...idproduct=2674 shoe pins
http://www.carolinasrc.com/Webstore/...idproduct=2675 spring
http://www.carolinasrc.com/Webstore/...idproduct=2683 spring
http://www.carolinasrc.com/Webstore/...idproduct=2696 spring
http://www.carolinasrc.com/Webstore/...idproduct=2773 flywheel
http://www.carolinasrc.com/Webstore/...idproduct=4505 shoes
and pending on what clutch bell you want to run you Might need to look into an adjustable motor mount.....im pretty sure the 808 does use the forward position motor mount anyways...but cant say for sure.
Old 04-10-2009, 04:41 PM   #20
CaseyP's Avatar
Marcus... pm me if you need some help with that Losi clutch.
<>< The Truth Will Set You Free!
TLR / Team Orion / Spektrum / AKA / TEKIN / Horizon Hobby / upgrade rc / AVID / SCH / SPY / HAL'S HOBBY WAREHOUSE
CaseyP is offline   Reply With Quote
Old 04-10-2009, 09:33 PM   #21
Frank L's Avatar
Trader Rating: 148 (100%+)
I am running 4 alum shoes and either green and gold or silver and gold. Both are killer combos. Stay away from the black they are way too soft. the green and gold was a little smoother but a little soft on torque with a .21. replacing the green with silver let the torque loose. As long as the inner diameter of the clutch bell is ok it doesn't eat the shoes. When too much of the inner diameter gets ground away I find it eats shoes every race day, Replace the bell and fixes the problem. Just my 2 cents
Old 04-10-2009, 09:46 PM   #22
Integra's Avatar
alum slag does not take away from the ID of the bell......it add's to it....and when you clean it its a matter of .02mm of steel you have removed....Silver Springs EAT shoes....there's no 2 way's around it....Dynamite max life....KH 7075....carbon wont last a heat.....im not tryin to be a jerk...but the silver's are way too stiff for most any application.
Old 04-11-2009, 08:18 AM   #23
We have ran Max Lifes, Losi Long wear and KH 7075 shoes with 2 gold and 2 silver in buggy and 4 silver springs in truggy for over 2 years with very little wear. Derek has ran several 2 and 3 day events including the 45 minute mains with one set of shoes and they still looked good after the mains.
gasser is offline   Reply With Quote
Old 04-11-2009, 08:46 AM   #24
air8's Avatar
gasser----do you mind letting us know what kind of engines you were using? I'll bet a modded or super powerful engine might be able to hold the shoes against the clutchbell harder, and reduce the slippage. Just a thought.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 04-12-2009, 12:21 AM   #25
Dynamite Platinum 21XP, Dynamite 053 pipe, Blue Thunder HP8 30%
Old 04-12-2009, 04:36 AM   #26
vladconnery's Avatar
Trader Rating: 35 (100%+)
I tried to run 4 silver springs with my Picco in my truggy. What a disaster that was those springs take to much power to make them lock up. Now golds or greens and you got some good snap going. 2 green 2 golds is a good place to start if you need more snap then go with 4 golds. Less snap go with 4 greens the black and the silver are either to lite (blacks) or to heavy (silver). Now if your running a C6 or a speed 4 silver might work. You will need that kind of power to make them lock on the bell.
Integra, Which OFNA CB are you using can you post a link to it? I always wanted to try a vented bell not sure which one would work with the Losi.
KO PROPO EURUS
Kyosho: TKI3, TKIe Tekin RX8 Gen2
vladconnery is offline   Reply With Quote
Old 04-12-2009, 06:00 AM   #27
RacerScott's Avatar
When installing a new losi clutch, should I blow the grease out of the large brearing that goes inside the bell?
VP powermaster fuel | Upgrade RC
Scott U.
RacerScott is offline   Reply With Quote
Old 04-12-2009, 07:25 AM   #28
YES however you don't want it to be bone dry. Just blow out the excess.
KO PROPO EURUS
Old 04-12-2009, 07:50 AM   #29
Integra's Avatar
C6 and speed will also slag out the shoes running silver's....its not a matter of how much power....but more thats the shoes SLip too much with big power .21's and they burn up.......this is the OFNA bell i run....the 4 vent is a hair or 2 shorter in depth then the 3 vent so it makes it easier to shim when all said and done
http://www.amainhobbies.com/product_...oducts_id/3651
Old 04-12-2009, 08:12 AM   #30
vypr2002's Avatar
I have a question, is there anyway to tell what spring you have by looking at them? I cant for the life of me remember what springs I had in there last year.
vypr2002 is offline   Reply With Quote
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 08:43 AM
Mugen MBX5R Nitro$junkie Nitro Off-Road 1503 04-23-2011 11:36 AM
Answer-RC's clutch shoes review Sylvain Nitro Off-Road 238 07-01-2010 07:17 PM
Adam Drake talks about the new 8ight 2.0 Sylvain Nitro Off-Road 545 05-30-2010 05:57 PM
