Old 04-07-2009, 01:00 PM   #1
jamiekerr14's Avatar
Default Tips Removing Old Hingepin?
Hey, Im helping a mate out oh his hyper 7.. And replacing the hinge pins. Im trying to get the Pins out.. and OMG.. What a pain, I cant seem to get the out.. I have used pliers.. I can get them so there flush one end.. and sticking out the other but no further.. And that's by smacking one.. end I have tried spraying WD-40 over the pin.. and moving it.. but it is fused to it.. any tips.. ?
Xray XB4
Supported By:
RC Disco
jamiekerr14 is offline   Reply With Quote
Old 04-07-2009, 01:06 PM   #2
wallot's Avatar
another hingepin and hammer always help.
DEX408 - Speed Passion Silver Arrow v2, LRP Dynamic 8
Dex410 V3 - Tekin RS Pro, 7.5t Redline
F1-09 - Tekin RS Pro, 17.5t Redline
Sakura Zero S - LRP Quantum, Saturn 20T
KoPropo Eurus
wallot is offline   Reply With Quote
Old 04-07-2009, 01:11 PM   #3
Yea, just done that with a Clamp too.. toke some serious beating haha.. but all done thanks..
Xray XB4
Supported By:
RC Disco
Old 04-07-2009, 01:24 PM   #4
rcgeezer's Avatar
Try grabbing the slightly exposed end with visegrips to get a good hold. I've had to use a small punch before to get it started. Best of luck!!
**Team Terribles Northern CA Regional Rep.**
Cold Fusion R/C Products Team Driver
Answer-RC USA / Team Sweep Racing USA
Team RcRenew...visit us at rcrenew.com!
Triton RC Alpha Plus Engines
rcgeezer is offline   Reply With Quote
Old 04-07-2009, 01:46 PM   #5
scwrod's Avatar
use a small hex driver.
hbracing.com tritonrc.com raceaka.com
scwrod is offline   Reply With Quote
Old 04-07-2009, 02:10 PM   #6
Send a message via AIM to Deznuts05
apply heat and see if that frees things up
however, if its that stuck you're probably better off replace'n the plastic as well
"Power is nothing without control" Ryuken
Deznuts05 is offline   Reply With Quote
Old 04-07-2009, 02:16 PM   #7
gubbs3's Avatar
I wouldn't recommend this. I've seen several hex tips chip when used to try and tap out a stuck hinge pin. Another hinge pin or punch is best.
gubbs3 is offline   Reply With Quote
